Use the equation of the straight line to predict future deaths.
The discussion centers on using a straight line to predict future cancer death rates based on a parabolic data set. Participants debate whether connecting only the first and last data points constitutes a valid function, with some asserting that a function requires a unique output for each input, while others argue that accuracy in prediction is not essential for defining a function. The conversation highlights that linear extrapolation from limited points may not yield reliable future predictions. Additionally, it is noted that a circle does not qualify as a function due to multiple outputs for a single input. Ultimately, the effectiveness of any extrapolation depends on the nature of the underlying data and the chosen model.
Gamma
Hello,
I have a set of data points to plot as graph.
X axis: Year
Y axis: Number of deaths due to cancer.
The graph is of parabolic shape opening to the right.
Following is my question:
I have been asked to plot only the first and last points and connect those points with a straight line. Use the equation of the straight line to predict future deaths.
Can this graph be considered as a function? I am not sure how to answer this. My answer is yes and No.
Yes because, by the definition of a function, you have a certain output for a certain in put. The definition does not worry about the accuracy of the output.
No because, two points in a set of data can not accurately predict the future outcomes.
Experts... what are your thoughts?
Thank You in advance.
Gamma
Hmm..seems like you're just plotting a linear function of x
This might sound a bit daft, but to answer your question another way let's say I decide that the best way to graph a cosine wave between -\pi and \pi is to use the following functions...
y = (\frac {2}{\pi})^2 (x+ \pi)^2 -1 on the interval [ -\pi,\frac {-\pi}{2} ]
y = -(\frac {2}{\pi})^2 x^2 +1 on the interval [ \frac {-\pi}{2},\frac {\pi}{2} ]and
y = (\frac {2}{\pi})^2 (x- \pi)^2 -1 on the interval [\frac{\pi}{2}, \pi]
Just because the method I employ is totally ridiculous does it make y = (\frac {2}{\pi})^2 x^2 +1, y = (\frac {2}{\pi})^2 (x+ \pi)^2 -1, ory = (\frac {2}{\pi})^2 (x- \pi)^2 -1 any less functions of x? :smile:
A function does not have to predict accurately the future outcomes. This a problem of modeling intelligently a situation.
A funtions is roughly defined as being a relation between to variables such as for each x, there is one and only one y which is associated to.
Hence, a linear relation between to variables is a function.
A circle does is not a function because for each x, there are two values of y that are associated. You must therefore take the upper (0,Pi) OR the lower (Pi, 2Pi) part of the circle to accurately describe it as a function.
Make sense. Thank you both for your thoughts. Regards,
Gamma.
To be correct, a circle is a function, but is a function of two variables (x and y). A function is simply a mapping from one set (call it A) to another set (call it B) such that every element of A corresponds to only 1 element of B.
No, a "circle" is not a function! It is a geometric object. What, exactly, is the function of two variables, f(x,y), that you are associating with the circle?
X axis: Year
Well it seems to me that if you want to extrapolate the function then clearly it is not the best approach to use a linear function that includes the first and last point of your original function.
That depends on the function that is inter/exra-polated. :smile:
If you were to plot number of cancer deaths per 1000 people per year, the function will become a lot flatter. Then you could go one step further and plot the growth of that number per year. Then your linear extrapolation would become a bit more meaningful.
