Using a differential to approximate a cube root
To approximate the cube root of 1.03 using a differential, start by finding the derivative of the function f(x) = x^(1/3) at a = 1, which gives f'(1) = 1/3. The linearization formula L(x) = f(a) + f'(a)(x-a) can then be applied, with L(x) simplifying to L(x) = 1 + (1/3)(x-1). Substituting x = 1.03 into this equation provides the approximation for the cube root of 1.03. This method is effective for values of x close to a, but may not be accurate for larger deviations.
jkeatin
Use the differential dy or L to approximate cubed root 1.03
L(x)= f(a) +f'(a)(x-a)
I have no clue how to start so that would be the most help, do i just find the derivative of cubed root 1.03 first?
You find the derivative of a^(1/3) at a=1 first. That's f(a). Then x=1.03. So x-a=0.03. Does that help?
so
L(x)= (a)^1/3+ 1/3(a)^-1/3(x-a)
substitue 1 for a only in the functions right
Your only equation was,
L(x)= f(a) +f'(a)(x-a).
This gives a good approximation to values of a function near x=a. So take the derivative of x^1/3.
f'(x)=d/dx x^1/3=1/3x^-2/3.
Now plug in a=1 and you should be good and you have an approximation near x=1.
Hope that helps.
is it l(x)= 1/3+1/3(0.03)
No, that's wrong. I'll work it out for you so hopefully you learn the process.
My other post said that f'(x)=1/3x^-2/3, I just used the exponent rule.
In the linearization, a is called the center and is where the linearization is most accurate. If we try to use it to find the cube root of 1000, it won't be very accurate.
The linearization around a=1 is,
L(x)=1^1/3+1/3(x-1)=1+1/3(x-1).
Now you just need to plug in x=1.03 to get the approximate value for the cube root of 1.03.
when you substitue 1 in f'(x) that equals 1^1/3?
or 1/3
Yes...
f'(x)=1/3*x^(-2/3)
f'(1)=1/3*1^(-2/3)=1/3*1=1/3.
sorry first time using this online thing i not used to way things are written, thanks for all your help.
  • · Replies 22 ·
  • · Replies 27 ·
