Using a transistor as a switch
  • Thread starter Thread starter Christo66
    Switch Transistor
A transistor can effectively be used as a switch to control a motor in a battery-operated digital timer circuit. A low threshold MOSFET is recommended for this application, as it can be driven directly by the 3.6V output from the timer. Suitable options include small signal NPN transistors like the 2N3904 or 2N2222, with the base connected to the timer's output. The resistor value should limit the base current to about one-tenth of the collector current, ensuring the transistor operates within safe limits. Proper selection of components based on current and voltage ratings is crucial for reliable operation.
Christo66
I have a battery operated digital timer circuit board that will control a small motor, via a control board.
The timer runs on 3.6vdc (batteries). The timers Output Control Signal is 3.6vdc when on, and 0Vdc when off. The timer is replacing an old analogue timer.
The old timer had normally open switch contacts.
I think that I will need a transistor to act as a switch, can anyone recommend a transistor and resistor (if needed) that would be suitable for this scenario?
What voltage and current levels do you need to switch Christo? You could probably use either a BJT or a low threshold MOSFET.
Low threshold mofets are designed to allow switching with gate voltages as low as 2.5 volts (some probably even lower). You may get a slightly better approximation to a short circuit with a mosfet compared with a BJT.
Thanks for the reply uart
I will run some tests to check out the current and volts, but to give you an idea of a similar motor see below:
6 Vdc
70mA no load
640mA full load
700mA stall
Cheers
Chris
6 Vdc
70mA no load
640mA full load
700mA stall
Cheers
Chris
A small low threshold mosfet would be ideal. You can usually drive the gate directly directly from the 3.6 volt logic output.
Using a transistor as a switch is a common and effective method in electronic circuits. In this scenario, a transistor can be used to control the flow of current from the battery to the motor based on the output signal from the timer. The type of transistor and resistor needed will depend on the specific requirements of the circuit.
For this application, a small signal NPN transistor such as the 2N3904 or 2N2222 would be suitable. The base of the transistor can be connected to the output control signal from the timer, and the collector can be connected to the positive terminal of the battery. The emitter can then be connected to the motor, allowing current to flow through the motor when the transistor is turned on.
The value of the resistor needed will depend on the current requirements of the motor and the gain of the transistor. A general rule of thumb is to choose a resistor that will limit the base current to about 1/10th of the collector current. For example, if the motor requires 100mA of current, a resistor with a value of 1kΩ would be suitable.
It is important to note that the transistor should be chosen based on its maximum collector current and voltage ratings, which should be higher than the requirements of the motor. Additionally, proper heat sinking may be necessary to prevent the transistor from overheating.
In conclusion, using a transistor as a switch is a suitable solution for controlling the motor in this circuit. The specific transistor and resistor chosen will depend on the requirements of the circuit, and it is important to ensure that the components can handle the necessary current and voltage.
Thread 'I thought it was only Amazon that sold unsafe junk'
I grabbed an under cabinet LED light today at a big box store. Nothing special. 18 inches in length and made to plug several lights together. Here is a pic of the power cord: The drawing on the box led me to believe that it would accept a standard IEC cord which surprised me. But it's a variation of it. I didn't try it, but I would assume you could plug a standard IEC cord into this and have a double male cord AKA suicide cord. And to boot, it's likely going to reverse the hot and...
9K
  • · Replies 58 ·
11K
  • · Replies 19 ·
