Using chain rule to differentiate x^x
To differentiate the function x^x using the chain rule, the discussion emphasizes setting up a function f(y,z) = y^z and using parametric equations where y(t) = t and z(t) = t. The chain rule is applied to find df/dt, resulting in the expression df/dt = y^z (z/y + ln(y)). The final derivative is established as (d/dx)(x^x) = x^x (1 + ln(x)). The conversation highlights the importance of correctly applying the chain rule and utilizing logarithmic properties to simplify the differentiation process.
Shakas
Use the chain rule to find (d/dx)(xx) by using the function f(y,z)=yz.
Chain rule: \frac{dz}{dt} = \frac{\partial z}{\partial x} \frac{dx}{dt} + \frac{\partial z}{\partial y} \frac{dy}{dt}
I honestly have no clue on how to use chain rule in this problem. I have spent about an hour trying to set up a chain rule equation and I have given up hope on finding one.
The partial derivatives of f(y,z) are:
\frac{\partial x}{\partial y} = zyz-1
\frac{\partial x}{\partial z} = yzln(y)
I have a strong feeling that I need to set up parametric equations somewhere to cancel out and get dy/dx, but I can't seem to find any possible way.
I know how to find the derivative using one-variable calculus, and it comes to out be [dy/dz = xx(1+ln(x))]. Any hints on how to setup a chain rule equation would be greatly appreciated, thank you.
Let y(t) = t and let z(t) = t. What you're looking for is then df/dt, which the fits the chain rule you posted nicely.
Alright so taking it a step further:
\frac{df}{dt} = \frac{\partial f}{\partial y} \frac{dy}{dt} + \frac{\partial f}{\partial z} \frac{dz}{dt}
y(t)=t
z(t)=t
\frac{dy}{dt} = 1
\frac{dz}{dt} = 1
\frac{df}{dt} = \frac{\partial f}{\partial y} + \frac{\partial f}{\partial z}
\frac{df}{dt} = zy^z-1 + y^z ln(y)
\frac{df}{dt} = \frac{zy^z}{y} + y^z ln(y)
\frac{df}{dt} = y^z (\frac{z}{y} + ln(y))
y=x
z=x
\frac{dy}{dx} = x^x (\frac{x}{x} + ln(x))
\frac{dy}{dx} = x^x (1+ln(x))
Thank you very much for your help.
The answer to your problem: (d/dx)(x^x) = y(x^x)...z is to be canceled out along the operations..try differentiating both sides of the equations.
First let y=x^x and
f(y,z)=u=y^z--->from here solve for y in terms of z, you can do that by getting the ln of both sides.
You will arrive at having: y=e^lnu.
Hope this could be of any help.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
