Using Crank-Nicolson Method to solve Heat Equation
robot1000
I'm a bit stuck with using the C-N method
The question I'm trying to solve is the standard heat equation with:
U=[sin(pi)*x] at \tau = 0
& U = 0 at x = 0
& x = 1 for \tau \geq 0
The intervals are 0.2 in x AND 0.02 in \tau up to \tau = 0.06
I've been asked to solve using an Explicit which I've done using formula derived from the taylor theorem, but the second part is asking to use the C-N Method.
I started using this formula:
in matrix form, where I'm letting r = 0.5 using
The only thing that's concerning me is that it seems a bit long winded and the answers for U(i,j) that have arisen don't seem at all close to the explicit method.
I put it all in matrix form and then using Gaussian elimination, is the correct method?
Update 1
I've managed to work through the first matrix for u(n,1) and seem to have gotten a good set of results. What I've noticed is that the u(1,1) = u(4,1) & u(2,1) = u(3,1).
Is it worth just skipping out the 3rd and 4th row in the matrix as I can just input the results from u(1,n) and u(2,n) into u(3,n) and u(4,n)?
Update 2
I misread the question, which actually just asked for the first time step which I had already calculated.
Thread 'Direction Fields and Isoclines'
I sketched the isoclines for $$ m=-1,0,1,2 $$. Since both $$ \frac{dy}{dx} $$ and $$ D_{y} \frac{dy}{dx} $$ are continuous on the square region R defined by $$ -4\leq x \leq 4, -4 \leq y \leq 4 $$ the existence and uniqueness theorem guarantees that if we pick a point in the interior that lies on an isocline there will be a unique differentiable function (solution) passing through that point. I understand that a solution exists but I unsure how to actually sketch it. For example, consider a...
