Using lightning for electrolysis
In summary, harnessing lightning into an electrolysis reaction could potentially produce a large volume of H2 gas. However, due to the high voltage and temperature, there may be side reactions and the need for specialized techniques such as distillation and multiple electrolytic cells.
triden
174
I was wondering what would happen if you somehow were able to harness a bolt of lightning into an electrolysis reaction? Normally you would use DC current and put 2 electrodes in a bucket of water. The water will split into 2 hydrogen and 1 oxygen molecule. With the lightning, you would have the lightning source current for one electrode and somehow attach the other electrode into the ground to make a large potential difference.
My question is: If you wanted to create a massive volume of H2 gas, could you put a lightning rod into the air and have the strike ionize the water and capture this into a tank that would store it? Assume that if you made too much H2 that there would be a bypass to stop the tank from exploding from the pressure
Lightning does react with elements, but not by electrolysis, one good example is that the extreme heat of a lightning breaks N₂, and O₂ bonds in the air, then these atoms rearrange resulting in O₃ and NO₂, nitrogen dioxide reacts with water and becoms nitric acid. Maybe a lightning striking the ocean may result in electrolysis since salt water does have a good amount of ions.
I think that the voltage would be so high you'd get a mess of side reactions that wouldn't be possible at regular voltages. Also due to the high voltage, the current would be high enough to heat the water to very high temperatures. Wikipedia says this: At elevated temperatures water molecules split into their atomic components hydrogen and oxygen. For example at 2200 °C about three percent of all H2O molecules are dissociated into various combinations of hydrogen and oxygen atoms, mostly H, H2, O, O2, and OH. Other reaction products like H2O2 or HO2 remain minor. At the very high temperature of 3000 °C more than half of the water molecules are decomposed, but at ambient temperatures only one molecule in 100 trillion dissociates by the effect of heat.
Using distillation methods... and some kind of bypass, it would definitely be possible to extract H2 in this way.
Also, using multiple electrolytic cells in series would decrease the voltage at each one.
Likes masacatior
What is electrolysis?
Electrolysis is a chemical reaction that uses electricity to break apart compounds into their component elements.
How does lightning help with electrolysis?
Lightning is a powerful source of electricity that can be harnessed to provide the energy needed for electrolysis to occur.
What types of compounds can be broken apart using lightning for electrolysis?
Lightning can break apart a variety of compounds, such as water, salts, and other ionic compounds.
What are the benefits of using lightning for electrolysis?
Using lightning for electrolysis is a sustainable and cost-effective way to produce hydrogen and other valuable elements. It also reduces the need for traditional energy sources, such as fossil fuels.
Are there any risks associated with using lightning for electrolysis?
While the use of lightning for electrolysis has many benefits, it can also be dangerous if not done properly. Careful precautions must be taken to ensure the safety of those working with the equipment.
  • Electromagnetism
  • Materials and Chemical Engineering
  • Electromagnetism
  • Electromagnetism
9K
