Backstageff
- 3
I've been going crazy over solving this problem properly. We were suppose to design a simple problem and then present it to the class, and i decided to solve this very question - is it more energy efficient to use the AC or open the windows on the highway?
the CdA for the car I am using (a 2007 Toyota Prius) is 0.67
i assumed air density was constant at 1.29
i am comparing a car traveling at different highway velocities (90 - 140 km/h)
The mass of the car is 1500 +1 person = 1565
When all 4 windows are open, drag increases by 20% (SAE http://www.liveleak.com/view?i=b9e_1214963046)
The AC increases fuel consumption from between 5% (low settings) to 25% (extreme external heat)
All other factors, excluding AC or open windows, are exactly the same in both trials
Cars do not stop for 100km and travel at uniform velocity. The trial begins after they have reached said speed.
There are 34.6M in 1L of gasoline (sorry Americans)
And the car consumes 4.9L /100km
Drag equation
Power to overcome drag
Using this model i have already arrived at a solution. When traveling at 105km/h the AC and force to overcome drag is approximately 46.94MJ. With just the windows open, the consumption is 44.12MJ. I realize that this model is painfully simple, but i would really like to know why these numbers are not entirely accurate for a real life situation. In a real situation, why is it more fuel efficient to drive with the AC on in the highway? What forces dramatically affect the trial with the windows open that the AC trial does not suffer from? I thought it had something to do with increasing RPM to overcome drag.. but everything in the car relies on RPM for power, so I am doubtful
Just Windows
D=1/2*ρ*v2*A*Cd=1/2*0.67m2*1.29kg/m3*(27.17m/s2)= 367.7N
Fnet= 367.7N * 1.20
W=(f * D)= (441.24N*100000m) / 10^6 J = 44.12 MJ
Just AC
D=1/2*ρ*v2*A*Cd= 1/2 * 0.67m2* 1.29kg/m3* (27.17m/s^2)= 367.7N
Fnet= 367.7N
W=(f * D)= (367.7N*100000m) / 10^6 J = 36.77 MJ
AC usage of 6% = 4.9 * 0.06 = (0.294 * 34.6) = 10.17 MJ
Total Fuel Consumption with AC = 46.94 MJ
