How can I integrate v² / (v² + 4) using arctan and u substitution?
fiziksfun
how do i integrate
v^2 / v^2 + 4
i understand this has something to do with arctan
but if i use u substitution to let v=(u/2) so (on the bottom) it becomes (1/4)(1+(v/2)^2)
there's still a v^2 on the top which the u substitution does not get rid of. Help :[
this is a bit of a gues but why don't you write it as
\int \frac{v}{2} \frac{2v}{v^2+4} dv
then do it by parts but for the 2nd term you can substitute u=v^2+4 giving \frac{du}{u}.
you'll get logs not arctans which i reckon is true because the your integral isn't of the form \int \frac{dx}{x^2+a^2}
Use polynomial division to rewrite \frac{v^2}{v^2 + 4} as 1 - \frac{4}{v^2 + 4}. Can you integrate it now?
...or that lol!
would't my method work as well?
latentcorpse said:
...or that lol!
Doing it your way, you'd have to evaluate \int ln(x^2+4) which evaluates to
4 tan^{-1}\left(\frac{x}{2}\right) + x \left(ln(x^2+4) - 2\right)
My way seems to be easier.
Let me summarize what happens your way, I switched v's to x's.
\int \frac{x^2}{x^2+4} dx = \int \frac{x}{2} \frac{2x}{x^2+4} dx = \frac{x}{2} ln(x^2+4) - \frac{1}{2} \int ln(x^2+4) dx = \frac{x}{2} ln(x^2+4) - \frac{1}{2} \left(4 tan^{-1}\left(\frac{x}{2}\right) + x \left(ln(x^2+4) - 2\right)\right)
Now obviously \frac{x}{2} ln(x^2+4) will cancel and you will be left with
x - 2 tan^{-1}\left(\frac{x}{2}\right)
This is the exact same answer you get if you do it my way:
\int \frac{x^2}{x^2+4} dx = \int 1 - \frac{4}{x^2+4} dx = x - 4\left(\frac{1}{2} tan^{-1}\left(\frac{x}{2}\right)\right) = x - 2 tan^{-1}\left(\frac{x}{2}\right)
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
