Vaidya metric and Wiki article
  • Thread starter Thread starter Mentz114
    article Metric
Mentz114
In the Wiki article http://en.wikipedia.org/wiki/Vaidya_metric it states that
...the Vaidya field is a pure radiation field rather than electromagnetic fields, and the emitted particles have nonzero rest mass.
but it looks to me as if the 'particles' are traveling at the speed of light ( null propagation vector field ) and so must have zero rest mass. Is this a typo or have I misunderstood something ?
Sure enough, it's a mistake. The matter in the Vaidya metric is what is known as "null dust". Zero mass but incoherent, it can be thought of as the high-frequency limit of electromagnetic radiation.
Thanks, Bill_K. I've edited the page. Now says 'zero rest mass'.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
