What Are the Dimensions of Constants in the Van der Waals Equation?
  • Thread starter Thread starter derekmvr
    Van der waals
The discussion centers on determining the dimensions of constants 'a' and 'b' in the Van der Waals equation, specifically in relation to pressure, volume, and temperature. Participants are asked to analyze the dimensions of 'b', concluding it must match the dimensions of volume, which is L³. For 'a', the conversation suggests it relates to pressure, hinting at dimensions that involve mass, length, and time. Additionally, the constant 'Z' is equated to 'R', leading to a discussion on its potential units. Overall, the thread seeks clarity on dimensional analysis within the context of the Van der Waals equation.
derekmvr
Hi everyone,
Struggling with the following question - maths and physics never been my strongest subjects. Thanks in advance
1. An equation of state that has been used to model the behaviour of a fixed amount of a real gas is:
(P+a/v2)(v-b)=ZT
In the equation Z, a, b are constants, and P represents pressure, V = volume, T = temp. The constant Z depends on the amount of gas.
Consider what the dimensions of a and b are in terms of the fundamental quantities of mass (M), length (l), and time (t).
2. Q1: The dimensions of b are:
a) L3
b) L6
c) M.L-1.T-2
d) M-1.L.T2
Q2: The dimensions of a are:
a) L6
b) M.L5.T-2
c) M.L-1.T-2
d) M.L-5.T-1
Q3: The value of the constant Z could be expressed in terms of the unit:
a) W
b) W.N.s-1
c) N.J.K-1
d) J.K-1
3. According to std van der Waal's equantion Z is equivalent of R, therefore Q3 = D, not sure about the calculations for Q1 or Q2
Any help would be greatly appreciated.
Thanks
derekmvr said:
Hi everyone,
(P+a/v2)(v-b)=ZT
a) L3
b) L6
c) M.L-1.T-2
d) M-1.L.T2
I'll help you with this one since it is the easiest. Without just giving you the answer I will explain by analogy. The portion of the equation that contains b is (v-b), right? You are subtracting b from the volume.
Now here is the hint/analogy... Can you subtract gallons from miles? Gallons from degrees C? No. What must the units of b... err be?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
