What is the Vapor Pressure of a Urea Solution at 24 C?
  • Thread starter Thread starter TypeFun
    Vapor
To calculate the vapor pressure of a urea solution at 24°C, first determine the molality of the solution by dissolving 9 g of urea in 10 mL of water, which has a mass of 10 g. Using Raoult's Law, the vapor pressure of the solution can be found by adjusting the vapor pressure of pure water (22.4 mmHg) based on the mole fraction of the solvent. Since urea is a non-volatile solute, it lowers the vapor pressure of the solution compared to pure water. The final vapor pressure can be calculated by applying Raoult's Law to find the adjusted value.
TypeFun
If you dissolve 9 g of urea (60.06 g/mol) in 10 mL of water, what is the vapor pressure of the solution at 24 C? Assume the density of water is 1.00 g/mL and the vapor pressure of pure water at 24 C is 22.4 mmHg.
Henry's Law, maybe? I'm not sure.
I have no clue. Help please.
Not Henry's, Raoult's.
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
