Variations in Refractive Index of atmosphere with altitude ?
The refractive index of air decreases with altitude due to the exponential decrease in air pressure and density. The relationship between the refractive index (n) and air density can be approximated as n - 1 being proportional to air density. A model for air pressure as a function of altitude is presented, leading to a formula for the refractive index at different heights. The discussion also covers calculating the time it takes for light to travel from a satellite to sea level, factoring in the refractive index. Overall, the calculations suggest that atmospheric effects on light travel time are significant but manageable with the right models.
kryptic3k
Variations in Refractive Index of atmosphere with altitude ??
The queries i have are related to refraction of light.
1. How does the refractive index of air vary with the altitude ? If possible explain the reason for change.
2. Does the amplitude of a wave change during refraction?
Science news on Phys.org
Refractive index increases from 1 in outer space to the refractive index of air at sea level.
I'm trying to find an expression for the refractive index of air at a certain height, anyone?
Thanks
To a good approximation, the quantity n-1 is proportional to the density of air. So using a table of air density, and the fact that n-1 is 2.9x10-4 at sea level (density = 1.2 kg/m3), you can get a good idea of the refractive index at different altitudes.
A table of air density vs. altitude is here:
http://www.usatoday.com/weather/wstdatmo.htm
More details, and a more accurate way to calculate n-1, is here:
http://www.kayelaby.npl.co.uk/general_physics/2_5/2_5_7.html
Note the formula after the words "For air at a temperature t °C and a pressure p Pa, ..." The expression shown is roughly proportional to p/tabsolute (with some minor corrective factors), which is proportional to density.
Great thanks, I actually assumed this. The pressure decreases exponentially with height, so I'll just align the two.
Thanks again.
You're welcome.
Note that n-1 is proportional to P/Tabsolute, not P. Assuming T is constant will skew the result.
Air pressure is proportional to density. I have found a model for air pressure:
\text{p0} e^{-z/7000}
Where p0 is the air pressure at sea level (101.33 kpa), z is the height in metres. It works surprisingly well with the table you gave above.
Then hence:
\text{n = } 1+0.00029 e^{-z/7000}
I have made a plot in mathematica:
[PLAIN]http://www.jamesandrews.eu/project/n_vs_height.jpeg
Note: x-axis is height from sea level in metres, y is n (unitless)
Does this sound reasonable?
Many thanks
At constant temperature, yes. Note that temperature does change with altitude, so this statement is an approximation.
Then hence:
Pretty reasonable, but you just might want to check it with a more accurate calculation that accounts for temperature changing with altitude. You can use the formula for ntp-1 at the http://www.kayelaby.npl.co.uk/general_physics/2_5/2_5_7.html" link I gave earlier.
Many thanks
You're welcome.
Great, thanks for your help. Well I'm just going to use this model here, it does match up roughly with the data you provided earlier.
I'm trying to calculate the time it takes for a signal to reach sea level, when emitted from a satellite 20,200km above sea level, with atmospheric effects.
Velocity is given by v = c/n(z) where n is the refractive index at height z above sea level.
v = (c/2.9/10^4)*Exp[z/7000]
Now, plotting this gives:
[PLAIN]http://www.jamesandrews.eu/project/v_vs_height.jpeg
Which seems pretty reasonable. How what I need is an expression to calculate the total time it takes for light to reach the Earth's surface, from a given height z.
I realize it will have to be some integral, but after an hour or so I have run out of steam.
Any help/pointers will be great.
Kind regards
\text{time} = \int {dt} = \int \frac{dx}{dx/dt} = \int \frac{dx}{v} = \int \frac{n \ dx}{c} \ \ \text{or} \ \ \frac{1}{c} \int {n \ dx}
Thank you so much, you are a genius. I actually got pretty close to that ;)
I have thought about this some more. The calculation you want can be done without detailed knowledge of the index-vs.-altitude dependence, you just need to know the pressure at sea level (or wherever the light beam is to be "observed") as well as at the satellite's altitude.
Note: fairly detailed solution follows; scroll down to the bottom for final result.
We want to know the time it takes for a light signal to reach a point on Earth at height h0 from a satellite located at altitude hs. The beam of light makes an angle θ from the vertical. If the beam is directed straight downward, then θ=0 and the cosθ factor that appears in the derivation is simply equal to 1 and may be ignored.
From before, we had
<br /> \begin{flalign*}<br /> \text{time} &amp; = &amp; &amp; \frac{1}{c} \int {n \ dx} \\<br /> \text{which may be written as} \\<br /> \text{time} &amp; = &amp; &amp; \frac{1}{c} \int {(1+n-1) \ dx} \\<br /> \\<br /> &amp; = &amp; &amp; \frac{1}{c} \int dx \ \ + \ \ \frac{1}{c} \int {(n-1) \ dx} \\<br /> \\<br /> &amp; = &amp; &amp; \frac{x}{c} \ \ + \ \ \Delta t \\<br /> \text{where} \\<br /> \Delta t &amp; \equiv &amp; &amp; \frac{1}{c} \int {(n-1) \ dx} \\<br /> \end{flalign*}<br />
In other words, the total time is simple the time x/c that light would take if traveling through a vacuum, plus an additional time Δt. We'll now derive an expression for Δt which does not involve any integrals.
Using the (very good) approximation that (n-1) is proportional to the density of air, ρ, we have
<br /> \begin{flalign*}<br /> n-1 &amp; = &amp; &amp; k \rho \ \ \text{ where } \ k \ \text{is a constant} \\<br /> \text{and so} \\<br /> \Delta t &amp; \equiv &amp; &amp; \frac{1}{c} \int_{x_0}^{x_s} {(n-1) \ dx} \\<br /> \\<br /> &amp; = &amp; &amp; \frac{k}{c} \int_{x_0}^{x_s} {\rho \ dx} \\<br /> \text{(Note } &amp; \text{the} &amp; &amp; \text{ inclusion now of the integration limits, indicating the observation point and the satellite position.)} \\<br /> \text{We know } &amp; \text{that} &amp; &amp; \text{ the pressure at an altitude} \ h_0 \ \text{is the weight of air mass above it in a unit-area, or} \\<br /> P_0 &amp; = &amp; &amp; \int_{h_0}^{\inf} \rho \ g \ dh \\<br /> \text{and} \\<br /> P_0 - P_s &amp; = &amp; &amp; \int_{h_0}^{h_s} \rho \ g \ dh \ \ \text{is the pressure difference between the two altitudes } h_0 \text{ and } h_s.<br /> \end{flalign*}<br />
Assume g is constant over altitude changes small compared to the 6400 km radius of the Earth.
Also, dh = dx cosθ, where θ is the angle of the light beam from vertical (i.e., "straight down" would mean that θ=0, cosθ=1, and dh=dx.
Continuing with the derivation:
<br /> \begin{flalign*}<br /> P_0 - P_s &amp; = &amp; &amp; \int_{h_0}^{h_s} \rho \ g \ dh \\<br /> &amp; = &amp; &amp; g \ \cos \theta \int_{x_0}^{x_s} \rho \ dx \\<br /> \text{so that} \\<br /> \int_{x_0}^{x_s} \rho \ dx &amp; = &amp; &amp; \frac{P_0 - P_s}{g \ \cos \theta} \\<br /> \text{and} \\<br /> \Delta t &amp; = &amp; &amp; \frac{k}{c} \int_{x_0}^{x_s} {\rho \ dx} \\<br /> \\<br /> &amp; = &amp; &amp; \frac{k}{c} \cdot \frac{P_0 - P_s}{g \ \cos \theta} <br /> \end{flalign*}<br />
We are getting there, but we need to know what the constant k is. As long as we know that the refractive index is nk at some known pressure and temperature Pk and Tk, then
<br /> \begin{flalign*}<br /> k &amp; = &amp; &amp; \frac{n_k-1}{\rho_k} \\ <br /> \text{where } \rho_k &amp; = &amp; &amp; \text{ air density at } P_k \text{ and } T_k, \\<br /> \text{Since} \\<br /> P \ V &amp; = &amp; &amp; N \ R \ T \ \text{, the (hopefully) familiar Ideal Gas Law,} \\<br /> \text{then} \\<br /> \rho_k &amp; = &amp; &amp; \frac{\text{mass}}{\text{volume}} = \frac{\text{moles}}{\text{volume}} \cdot \frac{\text{mass}}{\text{mole}} \\<br /> \\<br /> &amp; = &amp; &amp; (\frac{N}{V})_k \cdot m_m \ \text{, where } m_m = \text{ molar mass of air} \\<br /> \\<br /> &amp; = &amp; &amp; \frac{P_k}{R \ T_k} \cdot m_m \\<br /> \text{and} \\<br /> k &amp; = &amp; &amp; (n_k - 1) \cdot \frac{R \ T_k}{P_k \ m_m} \\<br /> \end{flalign*}<br />
Therefore
<br /> \begin{flalign*}<br /> \Delta t &amp; = &amp; &amp; \frac{k (P_0-P_s)}{c \ g \ \cos \theta} \\<br /> \\<br /> &amp; = &amp; &amp; \frac{1}{\cos \theta} \cdot \frac{R}{c \ g \ m_m} <br /> \cdot \frac{T_k \ (n_k-1)}{P_k} \cdot (P_0-P_s)<br /> \end{flalign*}<br />
And the total time is given by
time = x/c + Δt
Note: We are neglecting the deviation in θ due to refraction. We also neglect effects due to the Earths' curvature, which is okay as long as θ is not very close to 90o, i.e. the satellite does not appear close to the horizon when viewed from the observation point.
If I have time tomorrow, I'll put some numbers on this. Note that if R uses N/m2 pressure units then mm should be expressed in kg/mole, instead of the more familiar g/mole values given in the periodic table.
Yes, some numbers would be useful to verify this.
Using the previous method, I calculated that light was slowed down by (delta t) 3.33x10^-8 seconds.
So I am assuming that for nk = 1.00029 (sea level), this would mean that Pk would be the average pressure at sea level, and Tk would be the average temperature at sea level?
What would you use for Tk in this case? Obviously Tk varies quite a bit around the globe.
Kind regards
jamesa00789 said:
Using the previous method, I calculated that light was slowed down by (delta t) 3.33x10^8 seconds.
Without following the thread I can tell you these numbers don't make much sense, and the delay is wrong by orders of magnitude. 20k kilometers needs below 0.1 sec, 108 sec is several years.
Sorry, 3.33x10^-8 s
Much better now :smile:
At least there is no doubt it is a correct ballpark. 10-8 sec is the difference between light traveling 10 km in vacuum and in air at sea level.
Give or take some uncertainty and the assumptions made, that probably seems about right.
Something about these answers does feel right to me, for several reasons:
1) the index of refraction varies with wavelength and air can scatter quite a lot of light. Both of these depend on the composition of the air, which varies with altitude (water vapor, ozone, CO2, and the sodium layer, for example).
http://en.wikipedia.org/wiki/Sodium_layer
2) temperature effects have not been considered, and the temperature varies wildly with altitude:
http://www.physicalgeography.net/fundamentals/7b.html
3) optical transmission through the atmosphere is highly complicated- there are several codes that are used to model the process (HITRAN and MODTRAN, for example).
http://www.modtran.org/features/index.html#isr
http://www.cfa.harvard.edu/HITRAN/
So the question really becomes one of needed accuracy: something left out of this discussion as well.
time = x/c + Δt
Kind regards
Tk and Pk can be any temperature and pressure, and nk is the corresponding refractive index for that temperature and pressure.
The quantity Tk*(nk-1)/Pk, which appears in the equation for Δt, is very nearly a constant over a wide range of temperatures and pressures, and is equal to 7.90*10-7K/Pa.
Using g=9.8 m/s2, and mm = 28.97 g/mol = 28.97*10-3 kg/mol for air, we have
R / (c g mm) = 9.8*10-8 s/K​
Using these constants, my earlier equation becomes
Δt = 7.7*10-14 sec/Pa * (P0-Ps) / cosθ
For a satellite well above the atmosphere, we can take Ps=0. For P0 = 1 atm = 101,300 Pa at sea level, we get
Δt = 7.8 * 10-9 sec / cosθ
As a "common sense" check, this would be the time delay for light traveling through 1 atm pressure for 8 km, which is reasonable as that is roughly the "1/e" altitude of atmospheric pressure. The earlier calculation of 3.3*10-8s would correspond to 33 km at 1 atm, which seems to me to be too much.
Since we're talking about visible light, the refractive index does not vary much with wavelength over that range. And scattered light would not contribute to the effect we're calculating: the time delay of visible light traveling from some altitude to an observer at sea level.
H20 has a pretty small effect on refractive index, and I'm pretty sure CO2 concentrations are low enough to be negligible as well. If I have time and you're pretty certain we should check the magnitudes of the effects, I can try to find something quantitative. Ozone might be tricky, I'd have to see at what concentrations it can occur. If we're talking ppm levels, I can't see it mattering at the accuracy we're doing here.
I hadn't heard of the sodium layer before. The wiki article does not mention the density of sodium, but it would be interesting to quantify that.
My calculations are independent of the temperature profile in the atmosphere. The integral ∫(n-1)dx turns out to be proportional to the pressure difference between emitter and observer altitudes; detailed knowledge of the temperature-vs.-altitude is not necessary.
Basically, my calculations are at the two sig fig level for (n-1) and Δt. Gases that occur at the 1% level and less -- such as water and CO2 -- should be negligible.
Also about the ionosphere, due to solar radiation ionising gasses in the ionosphere, there are free ions wondering around which can effect some wavelengths of magnetic radiation.
Now, data being sent from satellites don't emit light, they emit radio waves with wavelengths of ~1cm, how would this effect this solution? I assume that we would just have to adjust nk for this wavelength?
I've used STP values n = 1.00029, T = 0C and P = 1atm and get 7.72*10^-9 s which is pretty close.
Yes, one would have to look up nk, at some temperature and pressure, for this wavelength.
I don't know the details of how ions affect things, and don't know what a good reference would be for looking that up. Googling ionospheric refraction of radio waves does yield some info:
http://www.google.com/#sclient=psy&...=1&bav=on.2,or.r_gc.r_pw.&fp=44b3839bd44fe786
