Varying resistance readings depending on how I connect my meter
  • Context: Undergrad
  • Thread starter Thread starter Martyn Arthur
The discussion centers around the varying resistance readings observed when measuring resistors connected through a breadboard versus direct connections. Participants explore potential reasons for discrepancies in resistance measurements, including the influence of the breadboard and the multimeter's accuracy.
  • Some participants note that the breadboard appears to add resistance, with one suggesting it adds approximately 0.4 ohms.
  • There are claims that the multimeter may not be functioning correctly, leading to inaccurate resistance readings.
  • One participant emphasizes the importance of understanding measurement instruments and suggests that breadboards can introduce additional resistance and capacitance.
  • Concerns are raised about the quality of connections made on the breadboard, with suggestions that contact resistance may be a factor.
  • Participants discuss the potential benefits of using a soldered PCB connection instead of a breadboard for more accurate measurements.
  • There is mention of the need for clarity regarding the setup used for measurements, including the type of connections and the multimeter's specifications.
Participants express differing views on the reliability of breadboards for accurate resistance measurements. While some agree that breadboards can introduce errors, others highlight the need for proper setup and instrumentation to achieve accurate readings. The discussion remains unresolved regarding the best practices for measuring resistance in this context.
Limitations include potential dependencies on the specific breadboard construction, the quality of the multimeter, and the nature of the connections used in the measurements. There are unresolved questions about the exact setup and the influence of various factors on the readings.
This discussion may be useful for individuals interested in electronics, particularly those exploring measurement techniques and the implications of using breadboards versus soldered connections.
Martyn Arthur
TL;DR
different readings from links in breadboard to direct meter connections
i have 1.6 ohm 2w resisors 3 samples all of which test 1.6 ohms when linked to meter. when tested through a breadboard they read 2 ohms; an explanation would so much be appreciated please?
Thanks
Martyn
The breadboard seems to add 0.4 ohms of resistance.
  • Agree
Thnks;but when I link the 3 they read 3.7 ohms?
Martyn
Its a bare circuit and has been tested at different points.
Martyn
Well, either your multimeter is not good and is not reading the actual resistances, or your breadboard is adding some resistance. I don't know what else to tell you. There really isn't another possibility.
If you have another multimeter then try the same measurements with a different device. Otherwise, try the same measurement multiple times with the same multimeter (completely take down and reassemble the circuit and all of the multimeter connections at least twice).
If you are confident that the multimeter works, then the breadboard is adding resistance. Your errors are small enough that it really could be either.
There is more contact resistance somewhere.
Depending on the breadboard construction, the contacts may be thin phosphor bronze shim, tin plated, and with little contact area.
How about a picture of the setup used to make the measurements.
Thanks I tried every option i could think of before reaching out to you; changed the resistors changed the breadboard and changed the monitor???? just don't know what else to try.
Martyn
If the multimeter is accurate then it is accurately telling you that the breadboard is adding resistance. There really isn't anything to "try", that is just physics. Breadboards add resistance (and capacitance).
Ok I can live with that; thanks or your help; I will try it with a clean pcb.
Thanks
Martyn
Wait, is this a soldered PCB connection, or a spring-loaded breadboard connection? As already mentioned, some pictures would help. Also, if these are power resistors, the leads may be too large for a simple plug-in breadboard...
https://learn.sparkfun.com/tutorials/how-to-use-a-breadboard/why-use-breadboards
3 x 1.6 = 3.7 ??
just pcb board connections of 3 series resistors and probes inserted adjacently
Martyn
I think you're just learning why I hardly ever used those things for my breadboards. Plus, they aren't stable or durable. Basically, I hate those things for wasting my time. It doesn't take long to solder after you place components.
Anyway, I'm not sure what to add, except that dealing with instrumentation issues is part of an EE's life. They all have issues at some point. It's your job to understand your measurements/instruments, not just to collect data blindly.
Seriously its a whole section of a course in one. Thank you; this closes it for me!
Martyn
Actually there are many possibilities. Positively the last system for accurate measurements of very high or low resistances / voltages or high frequencies / currents would be with a breadboard with clips. Breadboards are a quick and dirty method for testing viability of a basic idea. That would involve resistances of at least 10 Ohms and less than 10M, safe voltages and just a couple of Amps - you know what I mean. Breadboards are NOT simulations.
I can't find an actual schematic diagram of the set up so do we know how the meters have ben connected? How low resistance is the ammeter and does the PD measurement happen to include the drop across the ammeter. Even using the same meter to measure both quantities can affect what you get.
I'm staggered that so many people won't or can't solder joints.
Thanks for the response; soldered the resistors and readiinng was perfect; comments about breadboards noted with gratitude.
Martyn
Glad to be of help.
I learned those lessons many years ago (many). If you google resistance measuring techniques, look for a site with circuit diagrams and 'convincing' use of maths and terms. Treat Electrics the same as (your own) money. Intuition and stuff you can often hear can encourage sloppiness and inhibit success.
You can pretty much trust PF not to mis-lead you. Good luck.
Away to go then :smile:
Thanks again
  • · Replies 57 ·
14K
13K
