Vector calculus identities proof using suffix notation
The discussion revolves around proving a vector calculus identity involving the divergence of a cross product of two vectors, specifically \(\vec{\nabla}\cdot (\vec{a}\times\vec{b} )\) and its relation to curl operations on the vectors \(\vec{a}\) and \(\vec{b}\). The context is rooted in vector calculus and suffix notation.
  • The original poster expresses uncertainty about how to start the proof and suggests that it may involve a product rule. Some participants question the validity of the original poster's approach, particularly regarding the types of quantities involved in the cross product. Others suggest using component methods or the differentiation product rule to tackle the problem.
Participants are actively engaging with the problem, exploring different methods and questioning assumptions. Some have provided insights into using component notation and the product rule, while others have pointed out potential misconceptions in the original approach. There is no explicit consensus yet, but the discussion is progressing with various lines of reasoning being explored.
There is a mention of the original poster lacking resources, which may be affecting their ability to approach the problem effectively. Additionally, the discussion includes considerations of notation and the implications of parity in permutations related to the vectors involved.
U.Renko
I must become good at this ASAP.
prove [itex]\vec{\nabla}\cdot (\vec{a}\times\vec{b} ) = \vec{b} \cdot(\vec\nabla\times\vec{a}) - \vec{a}\cdot(\vec\nabla\times\vec{b})[/itex]
[itex]\vec a \times \vec b = \epsilon_{ijk}\vec a_j \vec b_k[/itex]
[itex]\vec\nabla\cdot = \Large\frac{\partial}{\partial x_i}[/itex]
summation over [itex]i[/itex]
I don't know where to start. I'm sure it must involve some product rule.
but I'm not 100% sure whether or not [itex]\vec\nabla\cdot(\vec a \times \vec b) = (\vec b \times\vec\nabla\cdot\vec a) + (\vec a \times \vec\nabla\cdot\vec b)[/itex] (or something resembling it)
...Right now I have no decent book with me and searching on the internet has done more harm than good.
If that identity correct I might (probably) be able to do the rest.
Look at the types of quantities you are using in your attempt at a solution. What type of quantity is ##\nabla\cdot \vec{a}##? Does it make sense to take a cross product of a vector with this quantity?
As for how to prove the necessary assertion. You can always go back and use components! The brute force method is always doable (and it's not so hard for this problem).
For a more elegant method of proof, none immediately come to mind. Perhaps with some more thought, one can find a more elegant proof.
Nope. it doesn't make sense.
what was I thinking...
Letting ##\partial_i \equiv \partial / \partial x_i##, we have
[tex]\vec{\nabla}\cdot (\vec{a}\times\vec{b} ) = \partial_i (\epsilon_{ijk} a_j b_k)<br /> = \epsilon_{ijk} \partial_i (a_j b_k)[/tex]
(using the Einstein summation convention). Now use the differentiation product rule, and simplify.
$$\vec{\nabla}\cdot (\vec{a}\times\vec{b} ) = \vec{b} \cdot(\vec\nabla\times\vec{a}) - \vec{a}\cdot(\vec\nabla\times\vec{b})=(\vec{b} \times\vec\nabla)\cdot\vec{a} - (\vec{a} \times\vec\nabla)\cdot\vec{b}=[\vec{b} \vec\nabla\vec{a}]-[\vec{a} \vec\nabla\vec{b}]$$
are several notations for the same thing
Though I personally like to include the parentheses some people do not. The justification for omitting the parentheses is that only one interpretation is possible. It is silly to make the nonsensical interpretation.
The problem you have is with parity of a permutation. Each switch in order changes the sign.
(123)=-(132)=(312)=-(213)=(231)=-(321)
we see that
$$\vec{b} \cdot(\vec\nabla\times\vec{a})$$
corresponds to (312) and thus has a positive sign
and
$$\vec{a}\cdot(\vec\nabla\times\vec{b})$$
corresponds to (213) and thus has a negative sign
Show that $$(1){~~~~~~~~~~~~~~~~~~~~~~~~~}\vec \nabla\cdot(\vec a \times \vec b) = \vec b \cdot (\vec \nabla \times \vec a) - \vec a \cdot (\vec \nabla \times \vec b){~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~}$$ Using suffix notation, we get for the left hand side of eq. (1) $$(2){~~~~~~~~~~~~~~~~~~~~~}[~\vec \nabla\cdot(\vec a \times \vec b)~]_i =\begin{cases} \begin{align}&~\partial_i (\vec a \times \vec b)_i = \partial_i (πœ€_{ijk} a_j b_k) = πœ€_{ijk} \partial_i (a_j b_k) \nonumber \\ & {~~~~~} πœ€_{ijk} [~b_k (\partial_i a_j) + a_j ( \partial_i b_k)~]~\dots\nonumber\end{align} \end{cases}$$For the right hand side of eq. (1), we obtain $$(3){~~~~~~~~~~~~}[~\vec b \cdot (\vec \nabla \times \vec a) - \vec a \cdot (\vec \nabla \times \vec b)~]_i =\begin{cases} \begin{align}& ~b_i ( πœ€_{ijk} \partial_j a_k) - a_i ( πœ€_{ijk} \partial_j b_k) \nonumber \\ &~πœ€_{ijk} [~b_i (\partial_j a_k)~] - πœ€_{ijk} [~a_i (\partial_j b_k)~] \nonumber\end{align} \end{cases}$$According to eqs. (1), (2), and (3) $$(4){~~~~~~~~~~~~~~~~~}πœ€_{ijk} [~b_k (\partial_i a_j) + a_j ( \partial_i b_k)~] = πœ€_{ijk} [~b_i (\partial_j a_k)~] - πœ€_{ijk} [~a_i (\partial_j b_k)~]{~~~~~~~~}$$ For the left hand side of eq. (4), we get after summing over ##k##
##{~~~~~~}(5){~~~~~~~~~~}πœ€_{ijk} [~b_k (\partial_i a_j) + a_j ( \partial_i b_k)~] =\begin{cases}\begin{align}& ~πœ€_{ij1} [~b_1 (\partial_i a_j) + a_j ( \partial_i b_1)~]\nonumber \\ & + πœ€_{ij2} [~b_2 (\partial_i a_j) + a_j ( \partial_i b_2)~]\nonumber \\ & + πœ€_{ij3} [~b_3 (\partial_i a_j) + a_j ( \partial_i b_3)~] \nonumber\end{align}\end{cases}##
Now ... 1st line of (5) ##j\neq1##, ##j## = 2, 3 ... 2nd line ##j\neq2##, ##j## = 1, 3 ... 3rd line ##j\neq3##, ##j## = 1, 2
##{~~~~~~}(6){~~~~~~~~~~}πœ€_{ijk} [~b_k (\partial_i a_j) + a_j ( \partial_i b_k)~] =\begin{cases}\begin{align}& ~πœ€_{i21} [~b_1 (\partial_i a_2) + a_2 ( \partial_i b_1)~] \nonumber \\ &{~~~~~}+ πœ€_{i31} [~b_1 (\partial_i a_3) + a_3 ( \partial_i b_1)\nonumber \\ & + πœ€_{i12} [~b_2 (\partial_i a_1) + a_1 ( \partial_i b_2)~] \nonumber \\ &{~~~~~} + πœ€_{i32} [~b_2 (\partial_i a_3) + a_3 ( \partial_i b_2)~] \nonumber \\ & + πœ€_{i13} [~b_3 (\partial_i a_1) + a_1 ( \partial_i b_3)~] \nonumber \\ &{~~~~~} + πœ€_{i23} [~b_3 (\partial_i a_2) + a_2 ( \partial_i b_3)~] \nonumber\end{align}\end{cases}##
Summing over ##i## as in the preceding, we find that
##{~~~~~~~~~~~~~~~~~~~~~}πœ€_{ijk} [~b_k (\partial_i a_j) + a_j ( \partial_i b_k)~] =\begin{cases}\begin{align}& ~πœ€_{321} [~b_1 (\partial_3 a_2) + a_2 ( \partial_3 b_1)~] \nonumber \\ &{~~~~~}+ πœ€_{231} [~b_1 (\partial_2 a_3) + a_3 ( \partial_2 b_1)\nonumber \\ & + πœ€_{312} [~b_2 (\partial_3 a_1) + a_1 ( \partial_3 b_2)~] \nonumber \\ &{~~~~~} + πœ€_{132} [~b_2 (\partial_1 a_3) + a_3 ( \partial_1 b_2)~] \nonumber \\ & + πœ€_{213} [~b_3 (\partial_2 a_1) + a_1 ( \partial_2 b_3)~] \nonumber \\ &{~~~~~} + πœ€_{123} [~b_3 (\partial_1 a_2) + a_2 ( \partial_1 b_3)~] \nonumber\end{align}\end{cases}##
Using the fact that ##~πœ€_{ijk} =\begin{cases}\begin{align} &~0~\text {if any index is equal to} \nonumber \\&~\text {any other index}~\dots\nonumber \\ &+1~\text {if}~i ,j, k~\text {form an} \nonumber \\ &~\text {even permutation (cylic}\nonumber \\ &~\text {permutation) of 1, 2, 3}~\dots\nonumber
\\ &-1~\text {if}~i ,j, k~\text {form an odd}\nonumber \\ &~\text {permutation of 1, 2, 3}~\dots\nonumber \end{align}\end{cases}##
##{~~~~~~~~~~~~~~~~~~~~~}πœ€_{ijk} [~b_k (\partial_i a_j) + a_j ( \partial_i b_k)~] =\begin{cases}\begin{align}& ~(-1) [~b_1 (\partial_3 a_2) + a_2 ( \partial_3 b_1)~] \nonumber \\ &{~~~~~}+ (+1) [~b_1 (\partial_2 a_3) + a_3 ( \partial_2 b_1)~] \nonumber \\ & + (+1) [~b_2 (\partial_3 a_1) + a_1 ( \partial_3 b_2)~] \nonumber \\ &{~~~~~} + (-1) [~b_2 (\partial_1 a_3) + a_3 ( \partial_1 b_2)~] \nonumber \\ & + (-1) [~b_3 (\partial_2 a_1) + a_1 ( \partial_2 b_3)~] \nonumber \\ &{~~~~~} +(+1) [~b_3 (\partial_1 a_2) + a_2 ( \partial_1 b_3)~] \nonumber\end{align}\end{cases}##
##{~~~~~~~~~~~~~~~~~~~~~}πœ€_{ijk} [~b_k (\partial_i a_j) + a_j ( \partial_i b_k)~] =\begin{cases}\begin{align}& ~ - b_1 (\partial_3 a_2)^* - a_2 ( \partial_3 b_1){\uparrow\uparrow} \nonumber \\ &{~~~~~}+ b_1 (\partial_2 a_3)^* + a_3 ( \partial_2 b_1){\uparrow\uparrow\uparrow}\nonumber \\ & + b_2 (\partial_3 a_1)^{**} + a_1 ( \partial_3 b_2)^{\uparrow} \nonumber \\ &{~~~~~} - b_2 (\partial_1 a_3)^{**} - a_3 ( \partial_1 b_2){\uparrow\uparrow\uparrow} \nonumber \\ & - b_3 (\partial_2 a_1)^{***} - a_1 ( \partial_2 b_3)^{\uparrow} \nonumber \\ &{~~~~~} + b_3 (\partial_1 a_2)^{***} + a_2 ( \partial_1 b_3)^{\uparrow\uparrow} \nonumber \end{align}\end{cases}##
##{~~~~~~}(7){~~~~~~~~~~}πœ€_{ijk} [~b_k (\partial_i a_j) + a_j ( \partial_i b_k)~] =\begin{cases}\begin{align}& ~b_1 [~(\partial_2 a_3) - (\partial_3 a_2)~] \nonumber \\ &{~~~~~} + b_2 [~(\partial_3 a_1) - (\partial_1 a_3)~] \nonumber \\ & + b_3 [~(\partial_1 a_2) - (\partial_2 a_1)~] \nonumber \\ &{~~~~~}+ a_1 [~( \partial_3 b_2) - (\partial_2 b_3)~] \nonumber \\ & + a_2 [~( \partial_1 b_3) - ( \partial_3 b_1)~] \nonumber \\ &{~~~~~}+ a_3 [~( \partial_2b_1) - ( \partial_1 b_2)~] \nonumber\end{align}\end{cases}##
Going back to the right side of eq. (4), we get after summing over ##k##:
$$πœ€_{ijk} [~b_i (\partial_j a_k)~] - πœ€_{ijk} [~a_i (\partial_j b_k)~] =\begin{cases}\begin{align}&~πœ€_{ij1} [~b_i (\partial_j a_1)~] - πœ€_{ij1} [~a_i (\partial_j b_1)~]\nonumber \\ &~+ πœ€_{ij2} [~b_i (\partial_j a_2)~] - πœ€_{ij2} [~a_i (\partial_j b_2)~]\nonumber \\ &~+ πœ€_{ij3} [~b_i (\partial_j a_3)~] - πœ€_{ij3} [~a_i (\partial_j b_3)~]\nonumber\end{align}\end{cases}$$ Summing over ##j##:
##πœ€_{ijk} [~b_i (\partial_j a_k)~] - πœ€_{ijk} [~a_i (\partial_j b_k)~] =\begin{cases}\begin{align}&~πœ€_{i21} [~b_i (\partial_2 a_1)~] - πœ€_{i21} [~a_i (\partial_2 b_1)~]\nonumber \\ &~+ πœ€_{i31} [~b_i (\partial_3 a_1)~] - πœ€_{i31} [~a_i (\partial_3 b_1)~]\nonumber \\ &~+ πœ€_{i12} [~b_i (\partial_1 a_2)~] - πœ€_{i12} [~a_i (\partial_1 b_2)~]\nonumber \\ &~+ πœ€_{i32} [~b_i (\partial_3 a_2)~] - πœ€_{i32} [~a_i (\partial_3 b_2)~]\nonumber \\ &~+ πœ€_{i13} [~b_i (\partial_1 a_3)~] - πœ€_{i13} [~a_i (\partial_1 b_3)~]\nonumber \\ &~+ πœ€_{i23} [~b_i (\partial_2 a_3)~] - πœ€_{i23} [~a_i (\partial_2 b_3)~]\nonumber\end{align}\end{cases}##
Summing over ##i##:
##πœ€_{ijk} [~b_i (\partial_j a_k)~] - πœ€_{ijk} [~a_i (\partial_j b_k)~] =\begin{cases}\begin{align}&~πœ€_{321} [~b_3 (\partial_2 a_1)~] - πœ€_{321} [~a_3 (\partial_2 b_1)~]\nonumber \\ &~+ πœ€_{231} [~b_2 (\partial_3 a_1)~] - πœ€_{231} [~a_2 (\partial_3 b_1)~]\nonumber \\ &~+ πœ€_{312} [~b_3 (\partial_1 a_2)~] - πœ€_{312} [~a_3 (\partial_1 b_2)~]\nonumber \\ &~+ πœ€_{132} [~b_1 (\partial_3 a_2)~] - πœ€_{132} [~a_1 (\partial_3 b_2)~]\nonumber \\ &~+ πœ€_{213} [~b_2 (\partial_1 a_3)~] - πœ€_{213} [~a_2 (\partial_1 b_3)~]\nonumber \\ &~+ πœ€_{123} [~b_1 (\partial_2 a_3)~] - πœ€_{123} [~a_1 (\partial_2 b_3)~]\nonumber\end{align}\end{cases}##
##πœ€_{ijk} [~b_i (\partial_j a_k)~] - πœ€_{ijk} [~a_i (\partial_j b_k)~] =\begin{cases} \begin{align}&~(-1) b_3 (\partial_2 a_1) - (-1) a_3 (\partial_2 b_1) \nonumber \\ &~+ (+1) b_2 (\partial_3 a_1) - (+1) a_2 (\partial_3 b_1) \nonumber \\ &~+ (+1) b_3 (\partial_1 a_2) - (+1) a_3 (\partial_1 b_2) \nonumber \\ &~+ (-1) b_1 (\partial_3 a_2) - (-1) a_1 (\partial_3 b_2) \nonumber \\ &~+ (-1) b_2 (\partial_1 a_3) - (-1) a_2 (\partial_1 b_3) \nonumber \\ &~+ (+1) b_1 (\partial_2 a_3) - (+1) a_1 (\partial_2 b_3) \nonumber\end{align}\end{cases}##
##πœ€_{ijk} [~b_i (\partial_j a_k)~] - πœ€_{ijk} [~a_i (\partial_j b_k)~] =\begin{cases} \begin{align}&~- b_3 (\partial_2 a_1)^{***} + a_3 (\partial_2 b_1)^{\uparrow\uparrow \uparrow} \nonumber \\ &~+ b_2 (\partial_3 a_1)^{**} - a_2 (\partial_3 b_1)^{\uparrow\uparrow} \nonumber \\ &~+ b_3 (\partial_1 a_2)^{***} - a_3 (\partial_1 b_2){\uparrow\uparrow \uparrow} \nonumber \\ &~- b_1 (\partial_3 a_2)^* + a_1 (\partial_3 b_2)^{\uparrow} \nonumber \\ &~- b_2 (\partial_1 a_3)^{**} + a_2 (\partial_1 b_3)^{\uparrow\uparrow} \nonumber \\ &~+ b_1 (\partial_2 a_3)^* - a_1 (\partial_2 b_3)^{\uparrow} \nonumber\end{align}\end{cases}##
##(8){~~~~~}πœ€_{ijk} [~b_i (\partial_j a_k)~] - πœ€_{ijk} [~a_i (\partial_j b_k)~] =\begin{cases} \begin{align}&~b_1 [~(\partial_2 a_3)- (\partial_3 a_2)~] \nonumber \\
&~+ b_2 [~(\partial_3 a_1) - (\partial_1 a_3)~] \nonumber \\
&~+ b_3 [~(\partial_1 a_2) - (\partial_2 a_1)~] \nonumber \\
&~+ a_1 [~(\partial_3 b_2) - (\partial_2 b_3)~] \nonumber \\
&~+ a_2 [~(\partial_1 b_3) - (\partial_3 b_1)~] \nonumber \\ &~+ a_3 [~(\partial_2 b_1) - (\partial_1 b_2)~] \nonumber\end{align}\end{cases}##
Comparing eqs. (7) and (8), we find that $$πœ€_{ijk} [~b_k (\partial_i a_j) + a_j ( \partial_i b_k)~] = πœ€_{ijk} [~b_i (\partial_j a_k)~] - πœ€_{ijk} [~a_i (\partial_j b_k)~]$$ $$ \Rightarrow{~~~~~~~~~}\vec \nabla\cdot(\vec a \times \vec b) = \vec b \cdot (\vec \nabla \times \vec a) - \vec a \cdot (\vec \nabla \times \vec b)$$
  • Β· Replies 9 Β·
  • Β· Replies 5 Β·
  • Β· Replies 5 Β·
  • Β· Replies 5 Β·
  • Β· Replies 3 Β·
  • Β· Replies 2 Β·
  • Β· Replies 12 Β·
  • Β· Replies 1 Β·
  • Β· Replies 2 Β·
  • Β· Replies 3 Β·
