Vector from origin and two points/please explain how to solve it
To solve the problem, a vector A needs to be determined from the origin to a point on the line between points r1 and r2, at a distance xr from r1. The distance r is defined as the difference between r1 and r2. It is suggested that sketching the scenario can aid in understanding the problem better. The components of vector A should be expressed in terms of r, r1, r2, and xr. Clarifying these components will help in formulating the solution effectively.
aigerimzh
Consider two points located at r1 and r2, separated by distance r=(r1-r2). Find a vector A from the origin to a point on the line between
r1 and r2 at distance xr from the point at r1, where x is some number
I have no ideas about this question, what do I have to find? Please help me
Drawing, or sketching the problem is always beneficial...
I took the liberty of doing it for you;
O-is the origin in this case... try figuring it out now, it should run along more smoothly...
Daniel
Daniel
Thanks a lot! But I can not understand a question. What should I find? Components of vector A? Or?
Yes, you need to express A using what you've been given, i.e r, r1, r2, xr...
Keep trying,
Daniel
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
