Vectors along surface of a sphere
  • Context: Undergrad
  • Thread starter Thread starter Dissonance in E
    Sphere Surface Vectors
6 replies · 6K views
Dissonance in E
I assume this is rather elementary so I'll be brief.
I have a point in an xyz coordinate system, this point is assumed to lie on the surface of a sphere with radius R. Suppose I know the coordinates of this point, how would I go about solving for the unitvectors pointing "due north", "due west", "due south" and "due east" along the surface of the sphere at this point ?
Thanks.
If a surface is parameterized by
[itex]\vec{f}(u, v) = \vec{r}[/itex]
then
[itex]\frac{\partial\vec{f}(u, v)}{\partial u}[/itex]
is a vector tangent to the surface in the u direction at that point
Normalizing such a vector will yield a unit vector.
Is there a way to solve the vectors using just a point on the axis and a unit vector towards the direction we want indicated ? I found something similar on the web, will this work?
"Let r2u be a unit vector from the center of the Earth's surface to
point 2. This unit vector is just a vector that's one unit long, but
pointing in the same direction as the vector r2. Let zu be the unit
vector in the z direction. Then you can construct a vector that
points "due north" along the Earth's surface from point 2 as:
north pointing vector = zu - (zu.r2u)r2u
The period in this expression connotes the scalar product of two
vectors. Similarly, a vector pointing along the Earth's surface from
point 2 toward point 1 (on a great circle) can be written as:
heading vector = r1u - (r1u.r2u)r2u
http://mathforum.org/library/drmath/view/52049.html
Let V = ai + bj + ck be the position vector to your point. Take the cross product
W = k cross V which will be perpendicular to both the k direction and your position vector V. Now take D = W cross V. This will be perpendicular to W, hence in the plane of k and V and it is perpendicular to V, so it is pointing either "North" or "South". Use D or -D, whichever has a positive z component.
ok so if i do something like this on matlab:
v = [3,3,3];
k = [0,0,1];
w = cross(k,v);
d = cross(w,v);
d = d/norm(d)
d =
0.4082 0.4082 -0.8165
i should get a unit vector d on point v that points towards point k ? will this work for arbitrary values of v & k ?
v = [3,3,3];
k = [0,0,1];
w = cross(k,v);
d = cross(w,v);
d = d/norm(d)
d =
The z component came out negative, so you want the opposite direction. But as I look at it more closely, if you let w = cross(v,k) instead of cross(k,v), you should get the right direction in the first place. To be sure you understand what the answer represents, if you draw the vector d with its tail at your original point on the sphere, d will be tangent to the sphere about the origin containing your original point and will point to the direction of the axis determined by the k vector, in this case the positive z axis.
