Vectors in different coordinate systems
6 replies · 2K views · last reply
Ahmad Kishki
how do i write vectors in polar coordinate? And what will the azimuth coordinate represent?
I was trying to figure out the vector connecting a ring to its center using polar coordinates, so that i would perform an integration over d(phi) (finding the electric field due to a semicircle at the origin). I wrote the vector as (-rho, phi,0) but then i ran into trouble with the units since the units of phi are radians. I worked this out in cartesian pretty easily but i am eager to know how this will work in polar, since polar here seems to me more natural.
Thanks in advance :)
I know the jacobian, and infact already found it in this case, but the issue is not here. Here the vector is included in the integration, but the phi component has units radians, while the rho has meters. The idea here is that maybe my idea about vectors in cylindrical / polar coordinates is wrong. This is so since the length of a vector can not be (rho + phi)^1/2 since the rho and phi have different units.
Handwritten sketch of a semicircular arc with a radius line at angle φ' from the horizontal axis; labelled dq = λR dφ' on the arc, a vector R̄ = (?) from the arc point to the centre, and below it E = ∫ dq / (4πε R²) · R̄/|R̄|.
Ahmad Kishki said:
jedishrfu said:
Welcome to PF!
I think you need to include the radius as one component. In your integration you need the Jacobian too
as in r dr dtheta which provides the missing units of measure.
Here's some info on polar coordinates and circles:
http://en.wikipedia.org/wiki/Polar_coordinate_system#circle
Show us your work and we can help you even better.
Here is the problem.. I am stuck at finding the vector that goes from the ring to the origin. And assuming i know that vector, which phi should i use to obtain the value of the electric field at the origin? I mean phi changes with position. I realize there is an easier way, but i want to know this way as well. (Sorry for multiple posts, this is my first time using a forum, soi am not sure i get the hang of it)
Handwritten sketch of a semicircular arc centred at the origin on a horizontal axis, with a radial line at angle phi' from the axis; labels read dq = R p dphi' on the arc, R-bar = ( ? ) on the vector from arc to origin, and phi' at the angle. Below is the integral E = integral of dq / (4 pi epsilon R^2) times R-bar / |R-bar|.
