What is the proper way to present mathematical problems on online forums?
The discussion emphasizes the importance of clearly presenting mathematical problems on online forums to facilitate understanding and assistance. Participants express frustration over the original post's lack of clarity, urging the author to properly format the problem statement and equations. The conversation revolves around the correct interpretation of the variable h, specifically ensuring it is negative as required by the problem. Clear communication is highlighted as essential for effective problem-solving in collaborative environments. Overall, the thread underscores the need for adherence to forum standards to enhance readability and engagement.
Muhammad Danish
Member warned to take more care when posting images
Is my solution correct? If not then please point out the mistakes and help me solve this question in the right way. Thanks in advance.
|a| = |b| |h|
so
|h| = |a| / |b|
and h<0
Likes Muhammad Danish
.Scott said:
|a| = |b| |h|
so
|h| = |a| / |b|
and h<0
After finding h, can we solve this question by matrix method? (The way I did)
You have h = -|b|/|a|.
It should be h = -|a|/|b|.
Then solve with b = a/h
If we make |h| the subject, it will be |h|= |a| / |b|. The answer will be positive. So | | signs will reverse the signs and give a negative value of h?
Right. We need to make h negative.
|a|/|b| is positive over positive, which is positive.
Per the problem, we need h to be negative...
So, h = -|a|/|b|
So, h = -|a|/|b|
How will it become negative?
If I use the equation |a| = |h| |b| then how can I get a negative value of h?
By using the equation: h = -|a|/|b|
Here's the sequence:
|a| = |h| |b|
|a|/|b| = |h|
so either h = |a|/|b|
or h = -|a|/|b|
But we know from the problem statement that it must be negative.
By removing ''| |'' from h, the other side will become negative?
I added some text to my last post.
Here it is again:
Here's the whole sequence:
|a| = |h| |b|
|a|/|b| = |h|
or h = -|a|/|b|
Here it is again:
|a| = |h| |b|
|a|/|b| = |h|
or h = -|a|/|b|
Like this?
Yes!
.Scott said:
Yes!
Thank you!
Your problem is totally unreadable. Please take the trouble to adhere to the PF standard, by typing out the statement of the problem. If you cannot do that, you should at least make sure you take a proper photo that will come out readable by the rest of the world.
