Velocitiy turns things into black holes?
  • Thread starter Thread starter ripoli85
    Black holes Holes
ripoli85
according to special relativity the mass of an object increases with its velocity by the lorentz factor. the lorentz faktor would be 2.3 for when traveling at 90% the speed of light. as you go faster and faster the lorentz factor increases. it would be 22.4 when traveling at 99.9% the speed of light(relative to our inertial frame of reference). that means that if something is traveling at 99.9% the speed of light it´s mass would be 22.4 times greater.
in particle accelerators single particles get so fast they have a mass several thousand times greater than that same particle would have standing still.
if, from that point on, you go on accelerating that particle even more, wouldn´t that particle at some point have gained enough mass that it turns into a black hole?
In Philippe G. Ciarlet's book 'An introduction to differential geometry', He gives the integrability conditions of the differential equations like this: $$ \partial_{i} F_{lj}=L^p_{ij} F_{lp},\,\,\,F_{ij}(x_0)=F^0_{ij}. $$ The integrability conditions for the existence of a global solution ##F_{lj}## is: $$ R^i_{jkl}\equiv\partial_k L^i_{jl}-\partial_l L^i_{jk}+L^h_{jl} L^i_{hk}-L^h_{jk} L^i_{hl}=0 $$ Then from the equation: $$\nabla_b e_a= \Gamma^c_{ab} e_c$$ Using cartesian basis ## e_I...
Abstract The gravitational-wave signal GW250114 was observed by the two LIGO detectors with a network matched-filter signal-to-noise ratio of 80. The signal was emitted by the coalescence of two black holes with near-equal masses ## m_1=33.6_{-0.8}^{+1.2} M_{⊙} ## and ## m_2=32.2_{-1. 3}^{+0.8} M_{⊙}##, and small spins ##\chi_{1,2}\leq 0.26 ## (90% credibility) and negligible eccentricity ##e⁢\leq 0.03.## Postmerger data excluding the peak region are consistent with the dominant quadrupolar...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
