Velocity of a sinussodial function
  • Thread starter Thread starter notsam
    Function Velocity
The discussion revolves around a sinusoidal function defined as x = (4.7 m) cos[(0.2 rad/s)(4.5 s)], with a focus on determining the magnitude of velocity v. Participants question the role of the "4.5 s" parameter, suggesting that a time variable 't' should be included for clarity in the function. The confusion stems from the expectation that the position should explicitly depend on time. This highlights the importance of correctly representing time-dependent functions in physics. Clarifying the function's parameters is essential for accurately calculating velocity.
notsam
A sinusoidal function of time is
x = (4.7 m) cos[(0.2 rad/s)(4.5 s)] .
Find the magnitude of the velocity v.
HELP! :)
What's the "4.5 s" parameter in the cosine function? Shouldn't there be a 't' variable in there if the position is a function of time?
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
