The discussion revolves around calculating the velocity of air exiting a nozzle connected to a compressed air tank. Participants explore various equations and principles related to compressible flow, including Bernoulli's equation and conditions for choked flow, while addressing the complexities introduced by varying pressure and temperature conditions.
- Technical explanation
- Debate/contested
- Mathematical reasoning
- One participant seeks a straightforward formula for calculating the speed of air exiting a nozzle from a compressed air tank.
- Another participant suggests using Bernoulli's equation, although later replies challenge its applicability to compressible flow.
- A participant emphasizes the importance of determining whether the flow is choked, indicating that if the pressure ratio is below a critical value, the flow will reach Mach 1 at the exit.
- Discussion includes the mass flow rate through the nozzle for choked flow, with a detailed equation provided for calculation.
- Some participants raise the issue of subsonic flow and the need to consider compressibility effects even at velocities below Mach 0.3.
- References to literature, including Shapiro's work on compressible flow, are mentioned as valuable resources for understanding the topic.
- Concerns are expressed regarding the specifics of the nozzle and tank configuration, which could affect flow characteristics.
- Questions arise about how to account for temperature changes when gas is venting from a tank, particularly in relation to propane gas.
- A participant discusses interest in un-choked flow and presents an equation for calculating velocity through a hole in a pressurized tank.
- Several participants recommend technical papers and textbooks as resources for further understanding compressible flow equations.
Participants do not reach a consensus on the applicability of Bernoulli's equation for this scenario, with some arguing it is inappropriate for compressible flow while others reference it in the context of subsonic conditions. The discussion remains unresolved regarding the best approach to calculate the velocity of air exiting the nozzle under varying conditions.
Limitations include the lack of specific details about the hose connecting the nozzle to the tank, the size of the reservoir, and the temperature effects on gas flow. The discussion also highlights the complexity of compressible flow regimes and the need for careful consideration of pressure and temperature conditions.
