Why Is Partial Differentiation Different in Polar Coordinates?
yungman
I just want to verify
For Polar coordinates, ##r^2=x^2+y^2## and ##x=r\cos \theta##, ##y=r\sin\theta##
##x(r,\theta)## and## y(r,\theta)## are not independent to each other like in rectangular.
In rectangular coordinates, ##\frac{\partial y}{\partial x}=\frac{dy}{dx}=0##
But in Polar coordinates,
\frac{\partial r}{\partial x}=\cos\theta,\;\frac{\partial \theta}{\partial x}=-\frac{\sin\theta}{r}
\frac{\partial y(r,\theta)}{\partial x(r,\theta)}=\frac{\partial y(r,\theta)}{\partial r}\frac{\partial r}{\partial x(r,\theta)}+\frac{\partial y(r,\theta)}{\partial \theta}\frac{\partial \theta}{\partial x(r,\theta)}=<br /> <br /> (\cos\theta) \frac{\partial y(r,\theta)}{\partial r}-\left(\frac{\sin\theta}{r}\right)\frac{\partial y(r,\theta)}{\partial \theta}
Thanks
If you calculate the partial derivatives at the end of your last equation, you'll see that the result is zero.
So ##\frac{\partial y}{\partial x}=0## for Polar coordinates.
Then I am even more confused!
r^2=x^2+y^2\Rightarrow\; r\frac{\partial r}{\partial x}=x+y\frac{\partial y}{\partial x}
\Rightarrow\; \frac{\partial r}{\partial x}=\frac{x}{r}+\frac{y}{r}\frac{\partial y}{\partial x}
If ##\frac{\partial y}{\partial x}=0##, then ##\frac{\partial r}{\partial x}=\frac{x}{r}##
Let's just use an example where ##\theta =60^o##, so to every unit change of ##x##, ##r## will change for 2 unit. So ##\frac{\partial r}{\partial x}=2##
The same reasoning, ##r=2x##. So using this example, ##\frac{\partial r}{\partial x}=\frac{x}{r}=0.5## which does not agree with the example I gave.
Please help, I've been stuck for over a day.
Thanks
If you fix θ, x and y get dependent, but then you are no longer in the general polar coordinates.
Likes 1 person
Thanks for your patience, I really don't get this. Even if I don't fix the ##\theta##,
\frac{\partial r}{\partial x}=\cos\theta\;\hbox { as }\;\frac{\partial y}{\partial x}=0
You can now put in ##90^o\;>\;\theta\;>45^o##, you'll get ##r>x## and ##\frac{\partial r}{\partial x}>1##
Here I am not fixing ##\theta##, I just use ##\frac{\partial y}{\partial x}=0## only.
I think I am serious missing something.
Now I am officially lost! I since posted this question in two different math forums, people there both asked and clarified, then it's been 12 hours with no response just like here!
I have one book and at least one article derived the equations like in my first post, but obviously the example I gave does not agree with the first post and I triple checked my example. I don't think I did anything wrong...apparently I have not get any suggestion otherwise from three forums! I am pretty sure I am missing something as the book I used is a textbook used in San Jose State and I studied through 7 chapters and yet to find a single mistake until the question here.
Anyone has anything to say?
From my example,
\frac{\partial{r}}{\partial{x}}=\frac{r}{x}=\frac{1}{\cos\theta}
And this answer makes a lot more sense.
Thanks
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
