Proving the Identity: cos(2x)-cos(4x)/sin(2x)+sin(4x)=tanx | Homework Help
  • Thread starter Thread starter Superstring
    Identity
The discussion revolves around verifying the trigonometric identity (cos(2x) - cos(4x)) / (sin(2x) + sin(4x)) = tan(x). Participants suggest using sum-to-product identities to simplify the expression, indicating that applying these identities should lead to a solution. One user expresses frustration after attempting various identities without success, leading to speculation about a possible typo in the original problem. Others encourage sharing specific work to identify where the misunderstanding may lie, emphasizing the importance of correctly applying the identities. The conversation highlights the challenges of proving trigonometric identities and the collaborative effort to resolve them.
Superstring
I'm supposed to verify this:
\frac{cos(2x)-cos(4x)}{sin(2x)+sin(4x)}=tanx
The attempt at a solution
I reworked it every way I could think of, but it just won't work. I got desperate so I plugged it into some site and it said it was not a real identity, so I now I'm thinking maybe my teacher had a typo or something.
look up the sum to product formulas for sine and cosine. They should help.
I already know them, but I still can't figure it out.
Try applying them.
rock.freak667 said:
Try applying them.
If you don't want to help then don't comment please.
Am I correct to assume you did not apply them?
No, you are not. Before I posted here I used the sum/dif identities, pythagorean identities, and double angle formulas. Everything I did resulted in a dead end.
Is it possible that you can post your work using the sum to product identities?
You can factor out sin2x from the denominator. Resolve it further as 2 sinx cosx, and write the right side as sinx/cosx. Eliminate cosx (assuming it is not zero). Divide both sides by sinx, and rewrite 2(sinx)^2 as 1-cos(2x). You can see that the denominator is equal to the numerator.
ehild
You didn't use the right ones then. You need the sum-to-product identities. If you use them, the answer pops out in like two lines.
Look for identities for cos a - cos b and sin a + sin b.
If, in fact, you used those already and didn't get anywhere, post what you did because that's where the difficulty lies.
