Is the Given Force Field Conservative?
leroyjenkens
Verify the following force field is conservative.
F = 2xcos2yi - (x2+1)sin2yj
∇xF=0
I'm pretty sure this is just a mistake in the book, but according to my calculations, this isn't a conservative force.
I used the determinant method to do the curl of F to find -2xsin(2y) + 4xsinycosy. Unless those two terms cancel each other to equal 0, then the force isn't conservative and there's a mistake in the book.
What do you think? Thanks.
You should brush up your HS trigonometry before doing anymore maths/physics. How do you expand sin 2y ?
Oh.
Is there a way to expand sin2y manually, or is it just one of those things you have to memorize?
Trigonometry generally appeals to memory even though some proofs can be visual. sin (x+y) = ? then take x=y.
\sin(2y) = 2\sin y \cos y for any angle y. So yes, the terms cancel out and the force is conservative.
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
