Verifying Subspace of P3: Closure of Addition & Scalar Multiplication
The discussion revolves around determining if a specific set of polynomials in P3, defined by the condition a0 + a1 + a2 + a3 = 0, forms a subspace. Participants emphasize the need to verify closure under addition and scalar multiplication, noting that the sum of two polynomials satisfying the condition also satisfies it. They highlight the importance of including the zero polynomial in the set to confirm it is non-empty, as a vector space must contain the zero vector. Additionally, they discuss showing that scalar multiples of polynomials in the set also meet the condition. Ultimately, the conclusion is that the set does indeed qualify as a subspace of P3.
Sho Kano
Determine if the following is a subspace of ##P_3##.
All polynomials ##a_0+a_1x+a_2x^2+a_3x^3## for which ##a_0+a_1+a_2+a_3=0##
use closure of addition and scalar multiplication
Let ##P=a_0+a_1x+a_2x^2+a_3x^3## and ##Q=b_0+b_1x+b_2x^2+b_3x^3##
##P+Q=(a_0+b_0)+(a_1+b_1)x+(a_2+b_2)x^2+(a_3+b_3)x^3##
am I missing a step? how can I show that matches the conditions?
Yes, because multiples ##c \cdot P## for whatever ##c## is from, must also be a polynomial that satisfies the condition.
What is the condition? Does ##P+Q## satisfies it?
You should also check whether the set is non-empty, which obviously is the case (why?).
the set is non-empty because all of the coefficients don't necessarily have to be 0?
fresh_42 said:
What is the condition? Does P+QP+QP+Q satisfies it?
I think it does, is this right? ##a_{ 0 }+a_{ 1 }+a_{ 2 }+a_{ 3 }=0\\ b_{ 0 }+b_{ 1 }+b_{ 2 }+b_{ 3 }=0\\ a_{ 0 }+a_{ 1 }+a_{ 2 }+a_{ 3 }+b_{ 0 }+b_{ 1 }+b_{ 2 }+b_{ 3 }=0+0=0\\ (a_{ 0 }+b_{ 0 })+(a_{ 1 }+b_{ 1 })+(a_{ 2 }+b_{ 2 })+(a_{ 3 }+b_{ 3 })=0##
No, empty set means no elements. But the polynomial ##P=0=0+0x+0x^2+0x^3## is not only an element, it is even needed, because a vector space must have ##0## in it.
Yes. And next also for ##c\cdot P## with a scalar ##c##.
As is, this doesn't make much sense. Start by assuming you have two functions that belong to your set. 1) Show that their sum is in the set. 2) Show that any scalar multiple of either of them is in the set.
Of course that polynomial is in the given vector space, but it wouldn't hurt to show that it is also in the subset of P3 defined by the equation ##a_1 + a_2 + a_3 + a_4 = 0##.
fresh_42 said:
Yes. And next also for c⋅Pc⋅Pc\cdot P with a scalar ccc.
##k\in \Re \\ kP=ka_{ 0 }+ka_{ 1 }x+ka_{ 2 }x^{ 2 }+ka_{ 3 }x^{ 3 }\\ ka_{ 0 }+ka_{ 1 }+ka_{ 2 }+ka_{ 3 }=k(...)=0##
so the subset is a subspace?
sorry I don't know if I wrote the set notation right
##S\in \left\{ a_{ 0 }+a_{ 1 }x+a_{ 2 }x^{ 2 }+a_{ 3 }x^{ 3 }|a_{ 0 }+a_{ 1 }+a_{ 2 }+a_{ 3 }=0 \right\} \\ P,Q\in S\\ P+Q=(a_{ 0 }+b_{ 0 })+(a_{ 1 }+b_{ 1 })x+(a_{ 2 }+b_{ 2 })x^{ 2 }+(a_{ 3 }+b_{ 3 })x^{ 3 }\\ (a_{ 0 }+b_{ 0 })+(a_{ 1 }+b_{ 1 })+(a_{ 2 }+b_{ 2 })+(a_{ 3 }+b_{ 3 })=0\\ k\in \Re \\ kP=ka_{ 0 }+ka_{ 1 }x+ka_{ 2 }x^{ 2 }+ka_{ 3 }x^{ 3 }\\ ka_{ 0 }+ka_{ 1 }+ka_{ 2 }+ka_{ 3 }=k(...)=0##
Yes. You should only replace the first ##"\in "## by ##"="##.
Edit: Do you know why these two imply ##0 \in S## and ##-P \in S## for ##P \in S\,##?
They are needed, because the vector space has to be a (additive) group. Why don't you have to show this separately?
No that's not the right explanation. Look at @fresh_42 comment for the right answer. You should always check that the set is non-empty, because only then you can show it is a subspace by showing the set is closed under vector addition and scalar multiplication. The easiest way to do this is by checking whether the zero vector is in it (which has to be part of every vector space). However, you can also take another vector and show that this vector is in the set.
The condition on p : x \mapsto a_0 + a_1x + a_2x^2 + a_3x^3 is equivalent to p(1) = 0. What is cp(1) + q(1) if p(1) = q(1) = 0 and c \in \mathbb{R}?
  • · Replies 23 ·
9K
9K
