Verifying that the uncertainty is 0 for a QM state
The discussion revolves around verifying the uncertainty of a quantum mechanical state, specifically focusing on the spin operators and their expectation values in different bases. The participants are analyzing the implications of using the z-basis versus the x-basis in the context of spin-1/2 systems.
  • Participants explore the calculation of expectation values for the spin operator ##S_x## and question the validity of their approaches. There is a discussion about the definitions of states and whether to work in the z-basis or x-basis. Some participants express confusion regarding the definitions and relationships between the states.
The discussion is ongoing, with participants providing observations and hints to each other. Some have pointed out potential mistakes in calculations and assumptions, while others are exploring different approaches to the problem. There is no explicit consensus yet, but the dialogue is productive, with hints and clarifications being shared.
Participants note the importance of treating coefficients as complex numbers and the implications of using different bases for the quantum states. There is also mention of the definitions of the states in the context of the spin-1/2 formalism, which adds complexity to the problem.
PhysicsKush
Verify that ##\Delta S_{x} = \sqrt{\langle S_{x}^{2} \rangle - \langle S_{x}\rangle^{2}} = 0## for the state ##\ket{+x}##.
$$\Delta S_{x} = \sqrt{\langle S_{x}^{2} \rangle - \langle S_{x}\rangle^{2}} = 0$$
$$ \ket{+x} = \alpha \ket{+z} + \beta \ket{-z}$$
$$ \langle S_{x} \rangle = |\alpha|^{2} \left( \frac{\hbar}{2}\right) + |\beta|^{2} \left( \frac{\hbar}{2}\right)$$
By definition , ##\ket{+x} = \alpha \ket{+z} + \beta \ket{-z}.## Therefore we proceed ,
\begin{align*}
\langle S_{x} \rangle &= \lvert \alpha \rvert^{2} \left(\frac{\hbar}{2}\right) + \lvert \beta\rvert^{2} \left(-\frac{\hbar}{2}\right) = (\alpha^{2} - \beta^{2})\left(\frac{\hbar}{2}\right).\\
\left(\langle S_x \rangle \right)^{2} &= \left(\alpha^{2} - \beta^{2} \right)^{2} \left(\frac{\hbar^{2}}{4}\right). \\
\therefore \Delta S_{x} &= \sqrt{\left(\frac{\hbar^{2}}{4}\right) - \left(\frac{\hbar^{2}}{4}\right)(\alpha^{2} - \beta^{2})^{2}} \\
&= \frac{\hbar}{2}\sqrt{1- \left(\alpha^{2} - \beta^{2}\right)^{2}} \\
&= \frac{\hbar}{2}\sqrt{1-(\alpha^{2} - (1-\alpha^{2}))^{2}} \\
&= \frac{\hbar}{2}\sqrt{1-(4\alpha^{4} - 4\alpha^{2} +1)} \\
&= \frac{\hbar}{2}\sqrt{4\alpha^{2} - 4\alpha^{4}} \\
&= \hbar \alpha \beta \neq 0 ?
\end{align*}
I don't understand what I'm missing or where I'm going wrong. Any indications would be appreciated.
\begin{align*}
\end{align*}
That's ##\langle S_{z} \rangle##, surely?
Right, that's a mistake. So ## \langle S_{x} \rangle = \lvert \langle+x | \varphi \rangle\rvert^{2}##, but I don't know what ##\varphi## is. Is it simply ##\langle S_{x} \rangle = \lvert \langle +x |+x\rangle \rvert^{2}## ?
Is there any reason to work in the z-basis? Why not the x-basis? Does the spin-1/2 formalism work just as well in the x-basis?
One problem is that the expectation value for ##S_x## looks wrong. You seem to have used ##S_x \lvert \pm \rangle = (\pm \hbar/2) \lvert \pm \rangle##, but ##\lvert \pm \rangle## are not eigenstates of ##S_x##. Note that you never seemed to use the fact that you're working with an eigenstate of ##S_x## as opposed to an arbitrary linear combination.
Hello, all we saw in class is that for 2-level systems
\begin{gather*}
\ket{\pm x} = \frac{1}{\sqrt{2}}(\ket{+z} \pm \ket{-z}) \\
\ket{\pm y} = \frac{1}{\sqrt{2}}(\ket{+z} \pm i \ket{-z})
\end{gather*}
and more generally,
$$ \ket{\varphi} = \alpha \ket{+z} + \beta \ket{-z}$$
From the equations above, I'm not sure if we saw a way to express ## \ket{+z} = \alpha' \ket{+x} + \beta' \ket{-x}##, i.e., a change of basis to ##\ket{\pm x}##. I've been spending hours and hours on this problem and I can't seem to get it right :(
I have also attempted the follwing approach:
Let ## \ket{\varphi} = \alpha \ket{+z} + \beta \ket{-z}##, then ## P_{x} = \lvert \langle+x | \varphi \rangle\rvert^{2}##. Now since ## \ket{+x} = \frac{1}{\sqrt{2}}(\ket{+z} + \ket{-z}),## it follows that
\begin{align*}
\lvert \langle+x | \varphi \rangle\rvert^{2} &= \lvert \alpha \frac{1}{\sqrt{2}} + \beta \frac{1}{\sqrt{2}} \rvert^{2} = \frac12 (\alpha + \beta)^2\\
\therefore \langle S_{x} \rangle &= \frac12 (\alpha+\beta)^2 \left( \frac{\hbar}{2}\right) + \left( 1- \frac12 (\alpha+\beta)^2 \right)\left( -\frac{\hbar}{2}\right) \\
&= \left( \frac{\hbar}{2}\right) \left((\alpha+\beta)^{2} -1 \right) \\
\implies \langle S_{x} \rangle^{2} &= \left( \frac{\hbar}{2}\right)^{2} \left((\alpha+\beta)^{2} -1 \right)^{2}
\end{align*}
Now since ##\alpha^{2} + \beta^{2} =1 \implies 1-\alpha^{2} = \beta^{2}##, the expression reduces to
\begin{align*}
\langle S_{x} \rangle^{2} &= \left( \frac{\hbar}{2}\right)^{2} 4\alpha^{2} \beta^{2} \\
\therefore \Delta S_{x} &= \sqrt{\frac{\hbar^{2}}{4} - \frac{\hbar^{2}}{4} 4\alpha^{2}\beta^{2}} \\
\Delta S_{x} &= \frac{\hbar(2\alpha^{2} -1 )}{2}
\end{align*}
Again with no success ! Could someone provide me a hint I went through all avenues that my mind can phantom with this problem :/
Before going through your working, some observations.
1) z is just an arbitrary direction. There must be no physical difference between ##|+z\rangle## and ##|+x\rangle##, other than different orientation of the axes in the lab.
2) Any measurement of ##S_x## in the ##|+x\rangle## state must return a value of ##+\frac {\hbar} 2##, by definition.
3) In your case ##\langle +x|\varphi \rangle = \langle +x|+x \rangle = 1##. You don't need to mess about with ##\alpha## and ##\beta##.
That said, it is a good exercise to calculate ##\langle S_x \rangle## for an arbitrary state ##|\varphi \rangle = \alpha |+z \rangle + \beta|-z \rangle##. So let me post where you went wrong below.
\begin{align*}
\end{align*}
\begin{align*}
\end{align*}
One problem here is that you don't treat ##\alpha## and ##\beta## as complex numbers. All your working is correct as long as ##\alpha## and ##\beta## are real. In general, you should get:
$$P_{x+} = \frac 1 2 + Re(\alpha \beta^*)$$
$$\langle S_x \rangle = \hbar Re(\alpha \beta^*)$$
If, however, we pick up from where you gave up and set ##\alpha = \beta = \frac 1 {\sqrt 2}##, then:
$$\Delta S_{x} = \frac{\hbar|(2\alpha^{2} -1)|}{2} = 0$$
You were nearly there!
Wow thank you so much ! Indeed, I completely dropped the absolute values and I did not think of setting ##\alpha \ \text{or} \ \beta = \frac{e^{i\delta_{\pm}}}{\sqrt{2}}##. Cheers!
