How Much Force Must a Rope Withstand in a Vertical Toy Spin?
The discussion revolves around a physics problem involving a 100g toy spun on a 30cm rope, questioning how much force the rope must withstand. Participants highlight the lack of necessary information, such as angular velocity, to determine the actual force required. They agree that the minimum force can be calculated if the tension at the highest point of the circle is zero, leading to a focus on using Newton's laws and centripetal acceleration concepts. The conversation emphasizes the importance of clear problem statements in physics exercises, as ambiguity can lead to confusion and wasted effort. Ultimately, the minimum force can be derived, but further details are essential for a complete solution.
Haigenoob
I have this exercise in physics, that i just don't know how to do.
"A child is spinning a 100g toy, which is attached to a 30cm long rope on a vertical level.
How much force does the rope have to handle?"
Well, the problem for me is, that there's no time given, how long it takes the child to spin it around or speed.
a = w^2 * r
w = v/r
w = φ-φo / delta t
w = φ/t
φ = 360 degrees = 2pi
Don't think i can use a = 9.8 m/s^2 for this, to find w and then the other things. Or may be it's just a trick exercise and the solution is just like F = m*a = 0.01m * 9.8m/s^2 = 0.98N?
But then again, the length of the rope should change the force that they toy has on the rope or is that not the case?
As you noted, the problem statement is incomplete.
Yeah, i know, but that's all that i was given. Is it possible then, it's just a trick question and the answer is as simple as F=m*a = 0.98N?
well it could be solved if question question was "what minimum force"
No, that would be the tension if the child was just holding the string with the toy dangling down, without spinning it.
Yes it could. It could also be solved if the angular speed was given. But neither was stated in the problem, as written.
but we can't do anything about angular speed ...
all we can do now is to find minimum force
Erm, what's the minimum force then if i may ask, and how do i find it?
for the minumum force, tension in string at hihgest point should be 0
You can find the minimum force, but why? the problem states
"How much force does the rope have to handle?"
You can only answer
"I have no idea, unless you tell me what its angular velocity is at a given point. I can tell you what minimum force the rope must handle in order to keep it moving in a circle, but I can't tell you what actual force it is required to handle unless you give me more information". This is an issue when the problem statement is unclear...you waste your time trying to figure out the answer, when there is none.
You can only answer
Yes i know, but please tell me anyways, what the minimum force is anyways and how do you find it. Just to know, because this is all the info i have and may be the teacher just specified the question wrongly
I told you already ... ofcourse in any case max force will be at lowest point,
and for that to be minimum, force at highest point should be 0
Perhaps the teacher omitted the word 'minimum', in which case it is a good exercise to calculate that minimum force requitred to keep it moving in a circle. Cupid.callin gave you a hint. Now you need to apply Newton's laws, centripetal acceleration concepts, and conservation of energy. Give it a try.
English is not my native language, so i have some trouble understanding exactly what it means :(
why not use google translater
it's not the words i don't understand, more like content. By lowest point you mean the end of the rope that the child is holding and the highest point, you mean the end of the rope tied to the toy?
If you agree that the tension force in the rope must be at least 0 at the top of the circle in order for the toy to move in a circle, then draw a free body diagram of the toy when it is in that position at the top of the circle. Examine the forces acting on it. Since T = 0, there is just one force acting down on it. Identify that force, then use Newton's 2nd law to solve for its centripetal acceleration, which you should be familiar with. This will allow you to find the speed of the toy at the top of the circle. Now find the speed at the bottom of the circle, using conservation of energy. Then look at the forces acting on the toy at the bottom of the circle, and solve for the rope tension using Newton 2 again.
The terminology "on a vertical level" seems unclear. Can you post the original language it was written in, without translating? When you level something, it usually means you ensure all points have the same vertical dimension, which means the points lie in a horizontal plane. Are you sure the circle of the given problem lies in a vertical plane? If so, it should say "in a vertical plane," instead of "on a vertical level."
Secondly, when not enough numerical data is given in a question, it usually means you write one or more parameters as a variable, and derive the answer in terms of the variables. But first, let us know the untranslated language of the question.
By the way, Haigenoob, always leave a space between a numeric value and its following unit symbol. E.g., 100 g, not 100g. See the international standard for writing units[/color] (ISO 31-0[/color]).
Got it done already, thank you for the help
