jcook735
- Messages
- 33
- Reaction score
- 0
Calculate the double integral.
∫∫((5x)/(xsquared)+(ysquared)) dA, R = [1,4] x [0,1].
Find the value of the integral.
Well I tried the integral starting with x and then starting with y and couldn't do it either way. Ill show the method using x first. To start off I tried using U-substitution to be able to integrate according to y. I had u = x^2 and du=2xdx. I pulled the 5 out of the equation, then put u in place of x^2 squared at the bottom of the equation, then put a 2 in the equation and a .5 outside the equation so i could replace 2xdx with du. So i ended up with the equation (5/2)∫du/(u+y^2). I then took the integral so that I ended up with (5/2) ln|u+y^2| (evaluated from 1 to 4). I then plugged in x^2 for u. So then I plugged in 4 and 1, and got ∫{(5/2)[ln|16+y^2| - ln|1+y^2|}dy. So then I set it up for the integral according to y. I used integration by parts on ln|16+y^2|, and got stuck. I found u=ln|16+y^2| and dv to equal dy. Then I found du to equal (2y)/(16+y^2) and v to equal y. I then plugged this into the given formula, vu-∫vdu. This is where I got stuck. How do I take the integral of vdu, aka (2y^2)/(16+y^2)? Help would be greatly appreciated.
