Very tricky double integration problem
  • Thread starter jcook735
    Integration
11 replies · 3K views · last reply
jcook735
Calculate the double integral.
∫∫((5x)/(xsquared)+(ysquared)) dA, R = [1,4] x [0,1].
Find the value of the integral.
Well I tried the integral starting with x and then starting with y and couldn't do it either way. Ill show the method using x first. To start off I tried using U-substitution to be able to integrate according to y. I had u = x^2 and du=2xdx. I pulled the 5 out of the equation, then put u in place of x^2 squared at the bottom of the equation, then put a 2 in the equation and a .5 outside the equation so i could replace 2xdx with du. So i ended up with the equation (5/2)∫du/(u+y^2). I then took the integral so that I ended up with (5/2) ln|u+y^2| (evaluated from 1 to 4). I then plugged in x^2 for u. So then I plugged in 4 and 1, and got ∫{(5/2)[ln|16+y^2| - ln|1+y^2|}dy. So then I set it up for the integral according to y. I used integration by parts on ln|16+y^2|, and got stuck. I found u=ln|16+y^2| and dv to equal dy. Then I found du to equal (2y)/(16+y^2) and v to equal y. I then plugged this into the given formula, vu-∫vdu. This is where I got stuck. How do I take the integral of vdu, aka (2y^2)/(16+y^2)? Help would be greatly appreciated.
hi jcook735! :smile:
(try using the X2 icon just above the Reply box :wink:)
that looks pretty good so far!
ok, you need to integrate 2y2/(16+y2)
just write it 2 - 32/(16+y2) :wink:
(the second part is a trig integral)
oh haha my bad I didnt know you could do that. why does y^2 turn into 32??
can yall check to make sure i did my integration correctly? for the equation you gave me, I should end up with 2y - (1/2)arctan(y/4), correct?
You need to write it out more clearly if you want people to check it. :wink:
But anyway, wasn't there an integral of something over (1 + y2) also?
Also, since this was a definite integral, you should end up with a number.
tiny-tim - That integral of something over 1 + y^2 was probably what turned into the arctan part.
alright my bad. I am taking the ∫2- 32/16+y2.
first, i separated the parts, so I have ∫2 - ∫(32)/(16+y2).
The first integral is 2y.
For the second integral, i pulled 16 out of the bottom, so i had (32)/((16)(1+(y/4)2)). I canceled out the 32 and 16, so i ended up with (2)/(1+(y/4)2). So then its 2∫(1)/(1+(y/4)2). This should turn out to be (8)arctan(y/4), correct?
So the whole equation should be 2y-(8)arctan(y/4).
That looks ok, but it was the whole thing that was bothering me :redface: …
you had " ∫{(5/2)[ln|16+y^2| - ln|1+y^2|}dy " in your first post, and the second bit seems to have gone missing.
Oh well I just needed help on the first part cause the second part followed suit. I got it right thank you both very much!
