Virtual displacement and generalised forces
The discussion revolves around the concepts of virtual displacement and work in mechanics, specifically the relationship between virtual work (δW) and generalized coordinates (q_k). There is confusion regarding the use of δ (for virtual quantities) versus ∂ (for partial derivatives), with participants suggesting that δW/δq_k may be a typo and should instead use partial derivatives. It is emphasized that δW represents work done by all forces during a virtual displacement while keeping other coordinates constant, and that forces can depend on q_k, complicating the use of partial derivatives. The conversation also touches on the implications of δW/δq_k and whether it can be expressed in terms of partial derivatives, leading to a proposed formula that incorporates both work and force dependencies. Ultimately, the distinction between virtual and actual changes in coordinates remains a key point of contention.
Gregg
I am unsure about the virtual displacement and work definition even after looking through the definition and seeming to understand it. If we have
## \delta W = \displaystyle \sum_{i} \vec{F}_i \cdot \delta \vec{r}_i ##,
I can use,
## \delta \vec{r}_i = \sum_{i} \frac{\partial \vec{r}_i}{\partial q_k} \delta q_k ##,
and get to
## \delta W = \displaystyle \sum_{k}\sum_{i} \vec{F}_i \cdot \frac{\partial \vec{r}_i}{\partial q_k} \delta q_k ##.
So,
##\delta W = \sum_{k} \mathcal{F}_k \delta q_k ##.
Then in the derivation it says that this imples that
##\sum_{i} \vec{F}_i \cdot \frac{\partial \vec{r}_i}{\partial q_k}= \mathcal{F}_k = \frac{ \delta W}{\delta q_k} ##.
I thought that ##\delta W = \sum_{k} \frac{\partial W}{\partial q_k} \delta q_k ## and ## \mathcal{F}_k = \frac{\partial W}{\partial q_k} ##. This seems to imply that:
## \delta W = \sum_{i} \frac{\delta W}{\delta q_k} \delta q_k ##,
so where is the distinction, because I can't work out when to use the deltas or ds?
F_{k}=δW/δq_{k} looks wrong to me. Probably a typo of δ for ∂ in both places. ∂W/∂q_{k} would be the limit of δW/δq_{k} as δq_{k} tends to zero.
Here ##\delta W ## is the work done by all forces for virtual displacement ##\delta q_{k} ## while no change in other generalized coordinates.
Don't forget that W depends on forces too, and the forces may depend on ##q_{k}##. Partial derivative is not correct here then.
The deltas are for virtual work / displacement not small change in ##q_k## etc.
Right, so what is actually implied by ## \frac{\delta W}{\delta q_{k}} ##? If partial derivative is not correct, is there a correct way in terms of the partial derivatices to express this? and is this the formal way to do so with the ##\delta##s?
I'm not sure but in my opinion, since δqk is arbitrary, we can set infinitesimal value to it and write the ratio in terms of partial derivatives:
\frac{\delta W}{\delta q_{k}} \rightarrow \frac{\partial W}{\partial q_{k}}+\sum_{i}\frac{\partial W}{\partial F_{i}}\frac{\partial F_{i}}{\partial q_{k}}
However I have never seem such formula perhaps because it's not useful. We often don't have W as a function readily.
Thread 'Gauss' law seems to imply instantaneous electric field'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Maxwell’s equations imply the following wave equation for the electric field $$\nabla^2\mathbf{E}-\frac{1}{c^2}\frac{\partial^2\mathbf{E}}{\partial t^2} = \frac{1}{\varepsilon_0}\nabla\rho+\mu_0\frac{\partial\mathbf J}{\partial t}.\tag{1}$$ I wonder if eqn.##(1)## can be split into the following transverse part $$\nabla^2\mathbf{E}_T-\frac{1}{c^2}\frac{\partial^2\mathbf{E}_T}{\partial t^2} = \mu_0\frac{\partial\mathbf{J}_T}{\partial t}\tag{2}$$ and longitudinal part...
