Understanding Virtual Particles and their Connection to Zero Point Energy
  • Thread starter Thread starter chromosome24
    Virtual
Virtual particles are transient entities that emerge from quantum fluctuations, existing momentarily in particle-antiparticle pairs and are linked to zero-point energy, which is the lowest energy state of a quantum system. The Casimir effect illustrates their influence, as it shows how virtual particles can create measurable forces, such as the attraction between two closely spaced metal plates due to an imbalance of virtual particles outside versus inside the plates. The discussion also touches on the distinction between real and virtual particles, emphasizing that real particles are those that can be observed and measured, while virtual particles serve as intermediaries in quantum interactions. Additionally, the behavior of virtual particles in magnetic fields raises questions about how they interact when fields attract or oppose each other. Overall, the conversation highlights the complex nature of virtual particles and their role in quantum mechanics.
chromosome24
can anybody explain to me virtual particles and how they related to the zero point energy?:confused:
In physics, the zero-point energy is the lowest possible energy that a quantum mechanical physical system may possess; it is the energy of the ground state of the system.
Virtual particles are particles that randomly pop in and out of existence in particle/anti-particle pairs due to weird quantum mechanical effects. At such small scales of time and space the uncertainty principle allows particles and energy to briefly come into existence, and then annihilate, without violating conservation laws.
A classic experiement showing the Casimir effect is one in which two microscopic metal bars are placed parallel to each other. What is so weird is that the bars snap together. The eplanation of the effect requires that the total energy of all of the virtual particles in the vacuum be added together, except for the ones in between. There are a lot more virtual particles outside the bars than inside, so the pressure presses them in. Although the virtual particles themselves are not directly observable in the laboratory, they do leave an observable effect: their zero-point energy results in forces acting on aforementionly arranged metal plates or dielectrics.
this article says
It is sometimes said that all photons are virtual photons. This is because the world-lines of photons always resemble the dotted line in the above Feynman diagram: the photon was emitted somewhere (say, a distant star), and then is absorbed somewhere else (say a photoreceptor cell in the eyeball). Furthermore, in the photon's frame of reference, no time elapses between emission and absorption. This statement illustrates the difficulty of trying to distinguish between "real" and "virtual" particles as mathematically they are the same objects and it is only our definition of "reality" which is at weakness here.
Could someone comment on that?
Is it correct to say that all fundamental fields are transmitted by virtual particle, but if these fields are disturbed, so if they set in wave motion then real particle (well-defined in energy) propagate and only then energy gets exchanged?
Ratzinger said:
this article says
It's always the same thing that bites us!
In a Feynman graph, the "external" (initial and final state) particles are the "real" ones, and the internal ones linking them are the "virtual" ones. But then it is up to you to decide when a particle is "an initial" one, and not itself part of a bigger interaction.
So where do you say that you *have* a (real) particle, and when do you consider it to be "intermediate" ?
Always the same measurement problem!
However, in practice, a particle is real when you can consider that the only state that contributes is a classically-like one. In that case, considering it as a virtual one would not make much difference, because the only contribution in the integral over all its potential states would be the "on shell" condition (namely, the condition that it is classically-like). In other words, no significant interference with "off shell" states occurs.
In that case, you can replace the integral over all "off shell" conditions by a single value, and then you've changed the virtual particle (in the integral) by a real one.
tell me if i am wrong
from what I've read the near magnetic field is compromised of virtual particles popping in and out of existence.
if this is correct how do the virtual particles of one magnetic field react with the virtual particles of a nother attracting or opposing magnetic field?
for example do the virtual particles of one field appear then shoot towards the other field before vanishing?
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
13K
