Voltage and Resistance Exercise, .
The exercise involves calculating the current and voltage across two resistors in series, R1=10 ohms and R2=30 ohms, with a total potential difference of V=12V. The total resistance is calculated as Req=40 ohms, resulting in a current of i=0.3 A. The voltage across R1 is -3V and across R2 is -9V, but voltage cannot be negative in this context as per Kirchhoff's Voltage Law, which states that the sum of voltages in a closed circuit must equal zero.
  • Understanding of Ohm's Law
  • Familiarity with Kirchhoff's Voltage Law
  • Basic circuit analysis techniques
  • Knowledge of series resistor configurations
  • Study Kirchhoff's Voltage Law in detail
  • Learn about series and parallel resistor combinations
  • Explore practical applications of Ohm's Law
  • Investigate circuit simulation tools like LTspice
Students studying electrical engineering, hobbyists building circuits, and anyone interested in understanding basic electrical principles and circuit analysis.
claudiadeluca
Please help with the following exercise:
Given 2 resistors in series R1=10 ohms, R2= 30 ohms, determine the current flowing through the resistors and the voltage across each resistor, if the potential difference across the wire is V=12V.
This is how I solved it:
The total resistance Req= R1+R2= 40 ohms
R = V / i
i = V/R = 0.3 A
V(R1) = -R1*i = -10*0.3= -3V
V(R2) = -R2*i = -30*0.3= -9V
Is it correct? Can the voltage be negative? Please help.
Thank you.
Voltage can be negative because it is a relative measurement.
I don't think you did yours right though. Draw the circuit out, and sum the voltages. They should sum to zero because of energy conservation, or otherwise known as Kirchoff's Voltage Law.
  • · Replies 18 ·
