Voltage, Current, and Resistance Calculations
13 replies · 2K views
a1234
I'm asked to find the voltage, current, and resistance through each resistor in the given circuit.
Req for parallel = 1/R1 + 1/R2 + ...
Req for series = R1 + R2 + ...
First, I want to find the total resistance in the circuit.
Since R3 and R5 are in series, is R35 = 18 ohms?
Then R4 and R35 would be in parallel, so 1/9 + 1/18 = 1/Req
Req = 6 ohms
6 + 9 + 2.5 = 17.5 ohms
Is this the total resistance in the circuit?
Req = 6 ohms
Yes, that is all correct.
Here are the calculations I have so far:
R1: 0.69 amps, 6.17 volts
R2: 0.69 amps, 1.17 volts
R4: 1.33 amps, 12 volts
For R3 and R5, am I supposed to consider them to be in series with the battery, or in parallel?
I agree with the current through R1 and R2 (but closer to 0.68?), and the voltage across R1.
Your voltage across R2 looks like a typo (transposed digits).
There is no way that R4 can have a larger current than R1 and R2.
For R2, the voltage is 0.69 * 2.5 = 1.725. I don't know how I ended up with 1.17.
For R4, I thought it was in parallel and did 12 = 9 * I to get I = 1.33 amps.
The current that goes through R1 gets split, some going through R4, the rest through R5 and R3.
Would the voltage going through R4 be different from 12 V?
12/17.5 = 0.69
0.69 * 9 = 6.17 volts
Would we work backwards to get 12 - 6.17 - 1.17 = 4.66, and divide that by 3?
The voltage drop across R4 is 12 - 6.17 - 1.71 = 4.12 V.
