Voltage drop in the internal resistance of a voltage source
The discussion revolves around the concept of voltage drop in the internal resistance of a practical voltage source, particularly in the context of circuit analysis involving a load resistance of 2 ohms. Participants explore the relationship between the internal resistance, load resistance, and current flow, while considering both ideal and practical voltage sources.
  • One participant suggests that the voltage drop occurs first in the internal resistance of the voltage source, with the remaining voltage appearing across the load, and questions whether the current through the load determines the voltage drop in the internal resistance.
  • Another participant asserts that the total resistance in the circuit, including the internal resistance, is relevant for applying Ohm's Law, implying that the internal resistance should be considered in calculations.
  • Some participants agree that in series circuits, resistances add up for calculations, and they discuss the implications of measuring voltage drops across individual resistances.
  • A participant mentions the need for two measurements to determine internal resistance, highlighting that the term 'internal resistance' is an approximation and that real-world behavior may be non-linear and time-dependent.
  • There is a claim that the current flowing through the load resistance influences the voltage drop across the internal resistance, which some find confusing.
Participants express differing views on the sequence of voltage drop and the influence of load current on internal resistance. There is no consensus on whether the current through the load determines the voltage drop in the internal resistance, indicating ongoing disagreement.
Participants mention the complexity of the relationship between load resistance and internal resistance, as well as the potential for non-linear behavior in practical voltage sources, which may complicate analysis.
Engineer1
In this circuit,first there will be voltage drop in the internal resistance of the voltage source.Mostly,the voltage source is assumed ideal in circuits,however,here a practical voltage source is assumed.
So,there will be voltage drop in the internal resistance of the voltage source which will depend on the value of the internal resistance and the remaining voltage will appear at 2 ohms load.The amount of current which flows through that 2 ohms load will depend on the value of the value of the voltage drop across the 2 ohms load.The more the potential difference across the 2 ohms load.the more current will flow.Is this right?
It is not the other way round that the value of the voltage drop in internal resistance is decided by the current which flows through 2 ohms load? First,there should be voltage drop in internal resistance and the remaining voltage should appear at 2 ohms load resistance and the amount of current in 2 ohms will depend on that voltage appearing across 2 ohms.Is that right.
You have a voltage source and a total resistance. It is irrelevant that some of the resistance is internal to the voltage source. Use Ohms Law.
Practical voltage source has internal resistance as well.Mostly,for circuit analysis ideal voltage source is taken and that internal resistance is not considered.
You're not listening to what I said. Why do you think I said you have a TOTAL resistance?
yes,in series the resistances add and accordingly the total voltage drop and thus the current flow.
In series resistances are added,this is what is done for calculations.But it is the same thing if one finds voltage drop at each resistance separately and thus the current flow.
I heard somewhere that the current flow in load resistance decides the voltage drop in internal resistance of voltage source.It seemed confusing.
Hey,thank you for your response. :smile:
Yeah, when you're starting out it can ALL be a bit confusing but it gets easy pretty quickly.
You always need two measurements for this; one with no load to give the emf and one with a known load resistance. That gives two equations and you can solve for the internal resistance.
But remember: the term 'internal resistance' is only a convenient approximation. Many sources will have a voltage drop under load which cannot be explained by a constant equivalent series resistance inside them. The effect is very often non-linear and can be time dependent if, for example, a battery warms up under load.
Yes. If you measure the voltage across the 2R then you know the current flowing in it. Since everything is in series the current flowing through the source and source resistance is the same.
Correct. The lower the load resistance the greater the current flowing and the greater the voltage drop across the source resistor. If you replaced the load with a short circuit (0R) then all of the source voltage would be across the source internal resistor. Beware this may not be safe to do in practice, the current might be dangerously high.
  • · Replies 105 ·
13K
  • · Replies 57 ·
14K
  • · Replies 24 ·
