What factors affect the induced voltage in an induction circuit?
Induced voltage in an induction circuit is influenced by the rate of change of current and the characteristics of the inductor. In a parallel R-L circuit, if the inductor in one branch opens, the voltage across that branch is expected to remain constant due to the voltage generator. However, without specific details or a diagram, it is difficult to determine the exact behavior of the circuit. Assuming a perfect inductor, the resistance would be zero, leading to theoretically infinite current and induced voltage. More information is needed for a definitive answer.
Osnel Jr
TL;DR
In a 2 Branch parallel r l circuit what would the voltage across the branch 2 to do if the inductor in branch 2 opens?
I'm thinking it would stay the same. Any answers?
Osnel Jr said:
Summary:: In a 2 Branch parallel r l circuit what would the voltage across the branch 2 to do if the inductor in branch 2 opens?
Do you have a diagram to help us figure out what you are asking about? Is this for schoolwork?
Assuming a voltage generator, the voltage stays the same irrespective of load.
Likes icesalmon and sophiecentaur
The induced voltage across the L will depend on the rate of change of current. There's not enough information to know that unless you assume that the Inductor is perfect. If it is perfect then it resistance would be zero so the standing current would be infinite and the induced voltage would be infinite too.
So your circuit description doesn't give us a possible answer - a diagram may help resolve this.
I am trying to understand how transferring electric from the powerplant to my house is more effective using high voltage. The suggested explanation that the current is equal to the power supply divided by the voltage, and hence higher voltage leads to lower current and as a result to a lower power loss on the conductives is very confusing me. I know that the current is determined by the voltage and the resistance, and not by a power capability - which defines a limit to the allowable...
  • · Replies 78 ·
  • · Replies 32 ·
