Volume Change by Pressure: How Does Pressure Affect the Volume of an Object?
The discussion focuses on calculating the volume of a 25 kg gold coin at a depth of 5000 meters, where the pressure is approximately 50.3604 MPa. Participants highlight the need to use the bulk modulus and thermal expansion coefficients to determine how pressure and temperature affect volume changes. Boyle's law and Charles's law are mentioned as potential methods for calculations, but there is confusion regarding their application to solids versus gases. The conversation emphasizes the importance of understanding the coefficients for volume change and the temperature of ocean water at that depth, which is around 3 degrees Celsius. Overall, the thread illustrates the complexities involved in calculating volume changes due to pressure and temperature in solid materials.
robax25
It is necessary to calculate the volume of the coin which has mass 25 kg and how does change its volume when it is necessary to calculate its volume at a depth of 5000m. Compare volume change by pressure with the volume change by pressure with the Volume change by temperature.
volume at surface, M=25kg ρ=m/v
v=1.294 * 10^-3 m³ density of gold ρ= 19320 kg/m³
v=1.294 * 10^-3 m³[/B]
I do not know how to calculate the volume at a depth of 5000m but I have pressure at a depth of 5000m.It is 50.3604 MPA. Now I need to find out Temperature using Pressure.
You are not told the temperature? Then how are you supposed to determine it?
Actually I need the volume at a water depth of 5000m . I can use Boyle's law to calculate Volume and charl's law to calculate Temperatur
I do not how to proceed
You are dealing with a solid, not a gas.
Do you know the equation for the volume change of a solid as a function of the temperature change and the pressure change?
Sorry, I don't know
robax25 said:
Sorry, I don't know
Do you have a textbook? Otherwise, Google "Bulk compressibility" and "Volumetric thermal expansion."
L=αLT however, I do not know the temperature
That's the coefficient of linear thermal expansion. The coefficient of volume expansion is 3 x as high.
I guess you need to look up the temperature of the ocean at a depth of 5000 m.
I get it 3 degree Celsius
Sorry, I learned this formula in structural Mechanics course but I forget it.
here I know only volume and how to proceed?
how can I calculate the volume at a water depth 5000m?
sorry, I get it but How to calculate volume change by pressure?
https://en.m.wikipedia.org/wiki/Bulk_modulus
Note, however, that there it quite correctly defines it as response to a small change in pressure. This is because, in principle, the modulus depends on the pressure, so what works for a small change won't work for a large one. But I think you'll have to overlook that subtlety.
  • · Replies 20 ·
  • · Replies 16 ·
