Volume in n Dimensions: Understanding the Meaning of n=0
The volume of a sphere in n dimensions is defined by the formula V(n) = (Π^(n/2)) / Γ((n/2)+1). When n=0, the result is 1, which can be interpreted as the volume representing a single point in zero dimensions. This relates to the Hausdorff 0-dimensional measure, which counts the number of points. Thus, in zero dimensions, the concept of volume simplifies to the existence of a single point. Understanding this helps clarify the mathematical interpretation of dimensions and volume.
Sheldon Cooper
Hello,
Surfing across the internet, I learned that the volume of a sphere in n dimensions can be expressed by
V(n) = (Π^(n/2)) / Γ((n/2)+1),
where n is the number of dimensions we are considering
But if we consider n=0, then we get 1. So, how do we interpret this? I mean what does volume in zero dimensions mean?
Thanks in advance :smile:
Mathematics news on Phys.org
Sheldon Cooper said:
Hello,
I am not an expert in this topic. If you want a simple answer, you can read Wikipedia, n-sphere
https://en.m.wikipedia.org/wiki/N-sphere
Yes, this seems to be a matter of computing the Hausdorff 0-dimensional measure which coincides with the number of points. See the formula in the article quoted in the above post.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
