daudaudaudau
- 297
- 0
naima said:I think that the volume integral of a "something"-density is the "something". (same as for a mass density)
Main article: Continuity equation
Because charge is conserved, the net flow out of a chosen volume must equal the net change in charge held inside the volume:
[itex]\int_S{ \mathbf{J} \cdot \mathrm{d}\mathbf{A}} = -\frac{\mathrm{d}}{\mathrm{d}t} \int_V{\rho \; \mathrm{d}V} = - \int_V{\left( \frac{\partial \rho}{\partial t} \right) \mathrm{d}V}\ ,[/itex]
where ρ is the charge density per unit volume, and dA is a surface element of the surface S enclosing the volume V. The surface integral on the left expresses the current outflow from the volume, and the negatively signed volume integral on the right expresses the decrease in the total charge inside the volume. From the divergence theorem,
[itex]\int_S{ \mathbf{J} \cdot \mathrm{d}\mathbf{A}} = \int_V{(\mathbf{\nabla} \cdot \mathbf{J}) \mathrm{d}V}\ .[/itex]
Hence:
[itex]\int_V{(\mathbf{\nabla} \cdot \mathbf{J}) \mathrm{d}V}\ = - \int_V{\left( \frac{\partial \rho}{\partial t} \right) \mathrm{d}V}\ .[/itex]
Because this relation is valid for any volume, no matter how small, no matter where located:
[itex]\nabla \cdot \mathbf{J} = - \frac{\partial \rho}{\partial t}\ ,[/itex]
which is called the continuity equation.[5][6]
naima said:When you integrate over a surface you get a quantity (the flow). Here it is not the integral of the dot product but
r*dot product. r is a vector.
So you do not find the same thing : you get a vector.
The aim is to see the current as a vectorial operator
which is done with i[H,P]
It is also the first time I see that.
I have still to convince myself that there is no pb with the
integration by parts.
blenx said:In classical electrodynamics, the volume integral of the current density is the time derivative of the electric dipole moment of the system:
[tex]\int {{\boldsymbol{J}}{{\text{d}}^3}V} = \sum\limits_i^{} {\int {{{\boldsymbol{J}}_i}{{\text{d}}^3}V} } = \sum\limits_i^{} {{q_i}{{\boldsymbol{v}}_i}} = \sum\limits_i^{} {{q_i}{{{\boldsymbol{\dot x}}}_i}} = {\boldsymbol{\dot d}}[/tex]
daudaudaudau said:Yes. What is the physical interpretation of such a quantity? Is it some sort of "total current"?
