Volume of cross sections using rectangles
  • Thread starter Thread starter mikaloveskero
    Cross Volume
The discussion focuses on finding the volume of a solid with rectangular cross-sections defined by the area under the curve y=√x, the x-axis, and the line x=9. The initial attempt at calculating the volume led to confusion, resulting in two different answers due to a miscalculation in the area formula. Clarification was sought regarding the orientation of the cross-sections, confirming they are perpendicular to the x-axis. The correct approach involves using the area A=(1/2)B*B, leading to a volume calculation through integration. Ultimately, the error in the initial area calculation was noted, emphasizing the importance of accurate mathematical representation.
mikaloveskero
The area bounded by y=√x, the x-axis and the line x=9 and is perpendicular to the x axis. find the volume of the cross section using rectangle with the h=1/2b
I just want to know if I'm correct or on the right track. if not please correct me
A=HB
A=(1/2B)B =3/2B
So i take the integral of 3/2B from 0 to 9
V=3/2 integral 0 to 9 B
V=3B^2/4 from 0 to 9
V=243/4
A=HB
A=(1/2B)B =3/2B
V=243/4
You haven't stated the problem clearly enough to be sure what it actually is, but I'm pretty certain your solution is wrong anyway.
Does the solid you are trying to describe sit on the described area with rectangular cross-sections perpendicular to the xy plane? Are the bases of the rectangular cross-sections in the xy plane perpendicular to the x-axis?
Yes, it does sit on the area with rectangular cross sections perpendicular to the x and y plane and the bases of the rectangular cross section are perpendicular to the x axis. I just need to find the volume using the given information.
Also i realize an error in my work :
A=HB
A=(1/2B)B =3/2√ x
So i take the integral of 3/2√x from 0 to 9
V=3/2 integral 0 to 9 x^3/2/(3/2)
V=6x^3/2/(6) from 0 to 9
V=162/6
or
The base is going to be sqrt(x). Therefore the height is 1/2sqrt(x), and the area is 1/2 x. The volume will be the integral from 0 to 9 of 1/2 x, which is 81/4.
i get two different answers
A=HB
A=(1/2B)B =3/2√ x
V=162/6
or
That's because (1/2)B*B doesn't equal (3/2)B.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
13K
