Volume of Rotation: Find Area Rotating Around Line
  • Thread starter Thread starter tree.lee
    Rotation Volume
The discussion revolves around finding the volume of a solid formed by rotating a specified area around the line x = 3. The area is defined by the curves x = y² and x = 1 - y².
  • Mixed
  • Participants explore the setup for calculating volume using either disks or washers, questioning the correct application of the formulas based on the given functions.
  • Some participants express confusion regarding the integration setup and the results obtained from computational tools, comparing their findings with textbook answers.
  • There are discussions about the interpretation of the radius in relation to the axis of rotation and the necessity of determining the correct expressions for the outer and inner functions.
Participants are actively engaging with each other's reasoning, with some providing guidance on the setup of the problem. There is acknowledgment of potential discrepancies in the textbook answers, and multiple interpretations of the problem are being explored.
Some participants note the confusion stemming from the integration limits and the definitions of the functions involved, as well as the possibility of typographical errors in the textbook.
tree.lee
Find volume when the area rotates around a line.
x=y^2
x=1-y^2
about x = 3
Could someone please check my formula for Area? I have pi[ (3-(y^2))^2 - (2-(y^2))^2 ] which gives me the integral pi[5y-(2/3)y^3]. I think it's wrong though because I plugged it into the wolfram alpha program and it gives me the wrong answer, the answer according to the textbook is (10)(sqrt2)(pi)/3 and the program says according to my integral between the intersection points (-1/sqrt2, 1/sqrt2) the volume would be (14)(sqrt2)(pi)/3. I'm really confused. Any help would be greatly appreciated! Thank you.
x=y^2
x=1-y^2
about x = 3
You are missing either ##\Delta x## or ##\Delta y##, which makes it harder for me to tell whether you are using disks or shells. I'm sure I could figure out what you're doing with some effort, but I shouldn't have to.
Oh, I think I'm using delta y. Like my widths are on the y axis? Is that what is meant? Sorry I'm not very good with terminology at all, haha.
The radius of your circles run parallel to the x-axis, and the summing of the areas occurs along the y-axis axis (the circles are vertically stacked), which gives us
[itex]∫\pi(x(y))^2Δy[/itex]
In this case, x(y) is not directly explicit. You have to use the given functions and the fact that it revolves around the x=3 axis to determine the real form of x(y)
I get the same number you got -- ##\frac{14 \pi \sqrt{2}}{3}##. Double-check the problem information and answer. If everything is as you reported, it seems that the book has a typo.
The above is incorrect. tree.lee is using "washers", or disks with holes in them.
Please read the problem more carefully. Both functions give x explicitly in terms of y.
x=y^2
x=1-y^2
about x = 3
3-(1-y^2) does not give 2-y^2.
Oh. Wouldn't subtracting the functions from x=3 give the distance from it and thus the radii desired? Then subtracting the inner function from the outer function should give the area I want to integrate, right? That gives me pi[5y-(2/3)y^3], doesn't it?
But the textbook says (10)(sqrt2)(pi)/3.
Yes, I know. It might be a typo in the book. That has been known to happen.
What book are you using?
I believe I got the answer. Let me type out my work and someone correct me if I'm wrong
tree.lee said:
Oh. Wouldn't subtracting the functions from x=3 give the distance from it and thus the radii desired? Then subtracting the inner function from the outer function should give the area I want to integrate, right? That gives me pi[5y-(2/3)y^3], doesn't it?But the textbook says (10)(sqrt2)(pi)/3.
OH I
Sorry I posted replies that I didn't mean to I'm new to this forum and there are a lot of brackets saying quotes and stuff and it confuses me and I'm not sure what I"m inputting when I hit post reply. Sorry. Thanks for the help A LOT! I did double check everything.
No. See my post #7.
Dick said:
No. See my post #7.
Yes, good eye, Dick -- you're right. The inner radius is (3 - (1 - y2)2, which is (2 + y2)2. Using that gives the textbook's answer.
Oh. Wow, this community is so cool. Thanks a billion. It's seriously appreciated. Hope you're all having a wonderful day. Thanks a lot Dick.
  • · Replies 20 ·
