Volume of Bubble at Bottom of Lake: 1.00 cm3
  • Thread starter Thread starter agadag
    Bubble Volume
The discussion focuses on calculating the volume of a bubble that rises from the bottom of a 40 m deep lake, initially having a volume of 1.00 cm³ at a temperature of 10°C. As the bubble ascends to the surface where the temperature is 31°C, the combined gas law must be applied to account for changes in both temperature and pressure. The pressure at the bottom of the lake is influenced by the water column, with 1 atm corresponding to 10 m of water, necessitating the inclusion of atmospheric pressure in the calculations. The final volume of the bubble just before it breaks the surface can be determined using these principles.
  • Understanding of the combined gas law
  • Knowledge of pressure conversion (1 atm = 10 m of water)
  • Basic principles of buoyancy and gas behavior
  • Familiarity with temperature conversion and its effects on gas volume
  • Study the combined gas law and its applications in fluid mechanics
  • Learn about pressure calculations in fluids, specifically hydrostatic pressure
  • Explore the relationship between temperature and gas volume in thermodynamics
  • Investigate buoyancy principles and their effects on gas bubbles in liquids
Students studying physics, particularly those focusing on fluid dynamics and thermodynamics, as well as educators seeking to explain gas behavior in varying pressure and temperature conditions.
agadag
A bubble with a volume of 1.00 cm3 forms at the bottom of a lake that is 40 m deep. The temperature at the bottom of the lake is 10°C. The bubble rises to the surface where the water temperature is 31°C. Assume that the bubble is small enough that its temperature always matches that of its surroundings. What is the volume of the bubble just before it breaks the surface of the water? Ignore surface tension. Answer in cm3
i wasn't sure how to go about solving this equation at all.
I know that : Change in V = k *V *change in Temp
PLEASE HELP!
At least you can ignore surface tension. The combined gas law is your best bet as temp and pressure are both changing. Recall that 1atm of pressure is equal to 10m of water. Be careful to include the regular barometric pressure at both the bottom and the surface.
  • · Replies 25 ·
  • · Replies 20 ·
