What happens to the units of L as n approaches infinity in hypercube volumes?
  • Thread starter Thread starter gmax137
    Volumes
As the dimension n of a hypercube approaches infinity, the volume behavior is contingent on the side length L. If L is less than 1, the volume approaches zero; if L equals 1, the volume remains 1; and if L is greater than 1, the volume tends to infinity. The choice of measurement units for L directly influences the resulting volume calculations, as unit conversions affect the scaling of dimensions. When considering limits, the arbitrary nature of measurement units becomes significant, impacting how volumes are interpreted in higher dimensions. Ultimately, the relationship between units and volume is crucial in understanding hypercube behavior as dimensions increase.
gmax137
Education Advisor
I am reading Julian Havil’s book Nonplussed, and in one chapter he’s discussing hypercubes, he says that the volume of an n-dimensional cube of side length L is L^n; then he goes on to note that as n-> infinity, the volume goes to zero if L<1; volume goes to 1 if L=1, and volume goes to infinity if L > 1. Ok that makes sense to me until I ask the units of L. I mean if I tell you that the side length is one meter, then 1*1*1*…1 =1 alright. Then I say, “oops, I meant one yard, so L= 0.914 meter” so now as n goes to infinity the volume is zero (0.914 * 0.914 * ...-> 0). I can see everything is OK as long as n is some finite number, because then we can say the volume is XXX (meters^n) which is equal to YYY (yards^n) and the difference is just a units conversion (=(m/y)^n). But what happens to the conversion factor “when n goes to infinity”?
Mathematics news on Phys.org
Exercise:
If you have a square of side length L and you scale up lengths by a factor of k, then how does the area get scaled?
That's the issue.
Yes, the limit will depend on what your units are. If this seems strange, you might think of a measurement as telling you how big the ratio of something is with respect to the thing that you decide has a length of 1. So, it is based on an arbitrary choice. Your choice of units of length will determine a choice of units for area, volume, etc, which, in turn, determines how big volumes are, which, in turn, determines what will happen when you take the limit.
Here's another way of thinking of it. Take one of the edges of a cube and chop in up into k pieces. Then, chop up the big cubes into little cubes with the corresponding side length. The number of cubes will go to infinity as you go to higher dimensions. That is the case when the length is greater than your chosen unit. If it is less than the units you chose--let's say half as big, you can do the same kind of thing. As the dimension goes to infinity, you will need more and more little cubes to build a cube of unit hypervolume, so the ratio is going to zero.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 125 ·
20K
  • · Replies 16 ·
15K
  • · Replies 31 ·
