VTOL Jet Engine Aircraft and VTOL Jet Engine
9 replies · 5K views · last reply
VTOL147
I am thinking about VTOL jet engine aircrafts like the following example (an ambulance).
Computer render of a futuristic jet aircraft in flight, with swept-back wings, a T-tail, a rear-mounted engine nacelle and a bulbous nose cockpit canopy.
To be able to buid that kind of aircraft VTOL jet engines are needed. At the moment there are no VTOL jet engines available, but I have my own proposal:
Cross-sectional schematic of a proposed VTOL jet engine with a bell-shaped casing, inner core, and red arrows showing airflow out through lower outlets, with a blue arrow on the right.
I have questions to jet engine experts. Is my design viable? Could the thrust-to-weight be over 50? What about a jet engine with following specs:
- thrust 8000 N (1800 lbf)
- weight 16 kg (35 lb), the thrust-to-weight ratio is 50
- height 300 mm (12")
- diameter 400 mm (16")
More: << Link to personal website deleted by the Mentors >>
While not an expert on jet engines, I have gathered operational data on a variety of VTOL aircraft via radar and tracking video and on models in wind tunnels. From your size specifications are you designing jet propelled model aircraft or drone with VTOL capability?
Welcome to the PF. :smile:
VTOL147 said:
(an ambulance)
How does the air ambulance in your rendering take off vertically? With only one engine on the high wing, I'm not able to picture how it can smoothly and stably take off and land vertically...
Afaik, the best lift engine ever produced was the RR RB162, with a listed 18.75 thrust to weight.
Getting to 50 would be a massive challenge, that is getting to rocket engine territory.
Note the RB162 had a dry weight of about 280 pounds, about 10x heavier than your notional item and delivered around 5500 pounds of thrust, with very low fuel efficiency.
Can you all see the pictures?
If not here they are again:
[Unacceptable links redacted by the Mentors]
anorlunda said:
Here's a previous thread on this topic.
https://www.physicsforums.com/threads/why-must-vtol-engines-be-larger-than-normal-engines.790352/
I am unclear how a VTOL engine differs from a regular jet engine.
VTOL jet engine is designed only for lift and land the aircraft. Ordinary jet engine could do that but they way too heavy for that at least without special/expensive materials.
There are eight VTOL jet engines in the air craft. The engines are for full size aircraft.
Throttle and possible pressurized air are used for take off and landing.
Afaik, RB162 was the only VTOL jet engine ever build but really newer used. It was tested with Dornier Do 31, but they didn't get it working.
RN162 was build at the beginning of 1060s. After that jet engines evolved a lot. Also materials have evolved.
I tested NASAs jet engine simulator EngineSim and I got T/W 75 with carbon fiber and ceramic option. Of cource this was without my design. I hope that my design would do more.
I honestly believe that the EngineSim is misleading you, as I do not think there is any experimental verification for the results. The numbers are probably right, but I suspect they reference unobtainium materials.
The RB 162 was indeed never put into service, but it was a state of the art design and metal technology has not advanced all that much since, the main temperature improvements have come with better turbine cooling and coatings. The limitation is still the compressor exit temperature, as components in that area are not easily cooled. Ceramics, which have been the hoped for solution, have not yet reached sufficient maturity to serve reliably.
Separately, the design you outline appears to have an annular intake, with the flow making 3 right angle turns to enter the combustor. There will be efficiency losses and it is a heavier structure than a straight through flow, so you must anticipate some big benefit from it that I do not see.
More broadly, a pure jet lift engine would be very hard to live with, the exhaust is more like a plasma torch than a hot wind, it melts the pavement. The Navy even had a hard time with the F35, even though the bulk of the lift is from a geared fan rather than the direct exhaust. A fan lift engine provides cooler exhaust and better mass flow, for very little extra weight.
Good luck in your efforts!
If your aircraft doesn't have to fly long distances, it is more economical and fuel efficient to use a conventional rotor (powered by turboshaft or piston engine) to provide the vertical lift. A turbojet or turbofan engine gives you a speed advantage that may not be big enough for short or medium distance trips to be worth the drawbacks.
New development: link
  • Cutaway rendering of a black cylindrical component with an orange-highlighted upper section and stacked dark rectangular plates on the sides, shown in a 3D CAD style.
Sorry, what's new about it? And is that your personal blog?
Thanks.
Update -- it is indeed his personal blog site, which is not an acceptable reference in the technical PF forums. Thread is done.
