Water Circling Drain Coriolis effect
The discussion centers on calculating the flow rate of water in a cone-shaped funnel influenced by the Coriolis effect, with specific parameters including a circumferential velocity of 5 m/s at a radius of 15 cm and a vertex distance of 20 cm from the drain. Participants suggest simplifying the problem by comparing it to a hockey puck sliding down an ice cone, emphasizing the conservation of energy, momentum, and angular momentum. The Coriolis effect is acknowledged as a minor pseudoforce that complicates the flow dynamics, but the fundamental physics remains accessible through proper breakdown of the problem.
  • Understanding of fluid dynamics principles
  • Knowledge of conservation laws: energy, momentum, and angular momentum
  • Familiarity with the Coriolis effect in physics
  • Basic geometry of conical shapes
  • Research fluid dynamics equations for conical flow
  • Study the effects of the Coriolis force on fluid motion
  • Explore conservation laws in rotational systems
  • Learn about practical applications of the Coriolis effect in meteorology and oceanography
Physics students, educators, and anyone interested in fluid dynamics and the Coriolis effect, particularly in preparation for Physics C tests.
ethopianprince
Lets say a cone shaped funnel was made as I was draining water (due to coriolis effect) and that there is a given circumferential velocity (lets say its 5m/s) at a certain radius of the cone (lets say 15 cm), also the cone's vertex is inside the drain and is a certain distance (lets say this is 20 cm) from the drain. In this case how would one get to figuring out the flow rate at the start of the cone (at r=15cm) and at the vertex of the cone?
Just a situation I would like to know about IF it shows up on the Physics C test(s), you can never be too sure :P
Welcome to PF;
Leaving aside the coriolis effect for a bit, and the water thing, and just look at a simpler system to try to understand what is going on. How about an ice cone with a hockey-puck sliding down it? Then you can use your understanding of sliding on a slope with negligible friction.
If you just drop the puck, it slides right down.
If you give it a sideways push, you can make is spiral down.
Having to stay in contact with the cone wall puts a constraint on the angle of the spiral.
Because of the constricting circle, the speed around the spiral also increases.
To work it out you need to realize that energy, momentum and angular momentum are all conserved.
Water flow can be derived by considering a small volume of the water being like the puck and the coriolis effect adds an extra very small pseudoforce.
So many things I don't want to think about at this hour -_- but thanks! a more step by step procedure would've been better but this way its better! thanks for your help!
Simon Bridge said:
Welcome to PF;
A step-by-step would be a "mindless walkthrough" ... you learn more this way.
What I'm hoping you'll see is that you already know the physics and the geometry to work it out as soon as the problem gets broken down.
So it's better to have a walkthrough in the sense it's easier and faster - but it is better this way for different and more meaningful reasons :)
Enjoy.
Haha I will! just not today.. sleep>physics
  • · Replies 24 ·
  • · Replies 30 ·
  • · Replies 18 ·
