'Water Cooling System: Can it Cool my Computer?
The discussion revolves around the feasibility of designing a water cooling system for a computer, specifically addressing the cooling requirements to reduce the temperature from 100°C to 40°C while managing a heat output of 600W from the components. Participants explore various aspects of the cooling system, including water flow rates, radiator efficiency, and alternative cooling fluids.
  • One participant questions the feasibility of achieving a flow rate of 0.1kg/s with only 0.2kg of water, suggesting that the proposed round-trip time and water speed seem unrealistic.
  • Another participant calculates the energy required to heat the water and compares it to the computer's heat output, indicating that the heat capacity of water could be sufficient if the flow rate is achieved.
  • A participant mentions a specific pump rated for 400 liters per hour, suggesting it could meet the desired flow rate and inquires about the necessary size of the radiator to dissipate heat effectively.
  • One participant provides equations relating airflow, temperature differences, and heat transfer, suggesting a required airflow of 75CFM for the system to function effectively.
  • Another participant offers assistance with thermal simulation software, indicating expertise in hydronic heating and cooling systems.
  • One participant raises concerns about the potential risks of using water in the cooling system, suggesting alternative coolants that would not pose a fire hazard or risk of short circuits.
  • Another participant discusses the use of a large aluminum heat sink and gravity flow to improve cooling efficiency, along with the need for an exhaust fan.
  • A later reply clarifies the concept of a "perfect radiator," acknowledging that while it is an unrealistic benchmark, there may be a significant safety margin in the calculations presented.
Participants express differing views on the feasibility of the proposed water cooling system, with some raising technical concerns and others suggesting alternative approaches. The discussion remains unresolved, with multiple competing ideas and no consensus reached on the best method or design.
Participants highlight various assumptions, such as the accuracy of the computer's power consumption rating and the effectiveness of the proposed cooling methods. There are also mentions of unit conversions and the need for precise calculations, which may not have been fully addressed.
JoonasN
Hi!
I am trying to design a water cooling system that could cool down my computer from 100C to about 40C, with 600W of energy being provided by the components. Could a system that moves 0.2l of water at 0.1kg/s from a water tank to the computer components to a radiator and from there back to water tank and around again, cool the system?
Joonas
How do you get 0.1kg/s with just 0.2kg of total water? A round-trip time of 2 seconds with a water tank looks strange. In addition, with a pipe cross-section of ~1cm^2, this would require a water speed of 1m, which is "a bit" more than I would expect.
Anyway, with your numbers and assuming a perfect radiator, the initial water temperature is similar to the room temperature or ~20°C. To heat 0.1kg of water to 40°C, you need 100g*4.2J/(g*K)*20K = 8.4kJ, while your computer just produces 600J per second. The heat capacity of water is more than enough, if you get that flow.
Hi!
I'm hoping to get the water to move at roughly 0.1kg/s by using this pump:
http://www.overclockers.co.uk/showproduct.php?prodid=WC-103-EK
It's rated for 400 litres per hour (max), so a bit over 0.1 kg/s.
Do you think I should have more water with the water moving at that speed? What do you mean by a perfect radiator? The radiator that I would use would use forced convection of air, with about 80CFM being blown on it from 4 sides. Is there a way to get a ballpark estimate about how big the radiator would have to be in order to dissipate the heat gathered by the water into the air?
You're mixing systems of units, but..
CFM*DT*1.08 = BTU
Lbw*DT=BTU
BTU=3.413*W
Lbw is pounds of water
DT is delta-T.
So let's say you have a 70 F room and want your water to max out at 95F or 35C. Using the equations I posted gets you a required airflow of 75CFM. So you're probably ok there. A good heat exchanger will get the water down to about 75F. I'll let you calculate the required flow rate of the water...
Let me ask you this though: how do you know the computer uses 600W? Is that the rating of the power supply? Odds are it is using much less than the rating.
This sounds like a complicated problem since you have transient variables. I have some expertise with a thermal simulation program I might be able to help you. PM me if you are interested. I use it for work almost every day and we work with hydronic heating and cooling systems.
i read ur problem, and i think u should consider some points
1)computer system can't alone rediate all the heat u must gather all the heat for the purpose of ease
'cause if u r going make water flow in all that delicate computer system it might turn into mess
2)i rather suggest u to use another coolent instead of water, which should not be fire catcher and nor could cause the short ckt in ckt if leaked
3) u should use the some nellpolish remover type coolent, 'cause in water cooled engines water is used 'cause it doesn't allow temp to icrease beyond 100 deg C.
In that order nellpolish remover type thing can easily gain input heat at 20 to 30 deg C from the system and can also rediate to the heat sink easily and ur overall system temp will be less than desired easily
4) Apply large alluminium heat sink at system and make coolent flow through it using gravity it will make cooling system requirements very less and another heat sink at radiator u r also going need a exhaust fan outthere. which will cool down the coolent to be again liquid.
5) Use "Calculus of Variation" to determine the coolent amount
and here u are done
u can reply me on purn.shodh@gmail.com
Perfect as in "cools water to environment temperature" - unrealistic of course, but as the calculation shows there is a big safety margin of a factor 10 (or more, if your actual power is lower).
  • · Replies 30 ·
  • · Replies 32 ·
  • · Replies 66 ·
