Can You Make a Telescope Using Water Drops?
  • Context: High School
  • Thread starter Thread starter SAZAR
    Drop Microscope Water
Creating a telescope using water drops is feasible by utilizing convex and concave lenses formed from water droplets on transparent surfaces. The discussion highlights the historical context of early microscopes using spherical glass beads and emphasizes the potential for magnification through stacked water lenses. Key challenges include evaporation of the water and achieving focus with multiple droplets. The construction can be accomplished with everyday materials like cardboard and transparent plastic, making it accessible for experimentation.
  • Understanding of basic optics principles, including lens types (convex and concave).
  • Familiarity with the concept of magnification and its measurement.
  • Knowledge of surface tension and its effects on liquid droplets.
  • Experience with DIY construction techniques using common materials.
  • Research the optical properties of water as a lens material.
  • Explore the historical development of microscopes, focusing on Antonie van Leeuwenhoek's designs.
  • Investigate methods to prevent evaporation in liquid-based optical systems.
  • Learn about the geometry of lens systems to optimize magnification with multiple water droplets.
Amateur scientists, DIY enthusiasts, educators in optics, and anyone interested in experimental microscopy techniques.
SAZAR
Is it posible to make a telescope using water drops?
(water drops are to be on transparent plastic or glass, set at desired distance; convex lense is a free drop, concave is a water drop in a ring (because of surface tension))
I think the first microscopes were basically small spherical glass beads acting as magnifying glasses and although the image quality must have been really poor several important discoveries were made with these glasses.Evaporation is the biggest problem I see with water droplets.Perhaps you could use a non volatile liquid.Good luck with it.
You may find it interesting to google "Leeuwenhoek"
google is your friend:
http://bizarrelabs.com/micro.htm
My idea was to stack elements with water drops to obtain greater magnification. (not just one water-lens (what... just x2 magnification))
I cut some transparent plastic (some food container; the shape of pieces was irregular - it doesn't mater) and placed water droplets on them but I couldn't find a focus for let alone a combination of just two of them.
I see that microscopes use only convex lenses (http://web.uvic.ca/ail/techniques/scope%20light%20path.jpg ) - which is nice for this experiment.
I would really like if someone with experience in optics could figure out the construction for this...
To help: the whole apparatus could be made using only cardboard and transparent plastic!
That's exactly the point of this all - ordinary objects one could find practically anywhere
Cut slits on two small cardboard rectangles and place them upright parallel to each other - they would hold transparent plastic pieces in place (stuck into slits) at preset distances according to optic properties of water.
It doesn't mater that water evaporates - if it can magnify, say, x200 for one minute that's enough.
...Circles could be drawn or etched in plastic so you can easily repeat "construction of lenses" i.e. water drops - drops would be bigger or smaller according to needs to suffice optical construction for desired magnification (200x ...even 600x :D wow!) using water as lens material...
OK, some time has passed - did someone try to figure out geometry to make say 300x magnification with multiple water drops "optical system" (lol)?
(By the way - does it mater how light rays enter eye - I mean - do they have to be parallel or can they by like focusing/diverging and you still see everything sharp (I mean - I guess there is a limit to what eye lens can sharpen-up...))
  • · Replies 16 ·
  • · Replies 18 ·
  • · Replies 20 ·
