Water Evaporization from standing sinks
  1. Sep 14, 2005 #1
    I'm trying to confirm if the following formula is correct for determining the rate of evaporization in lbs/hr from standing water in a sink.
    Formula W=[A+(B)(V)](PA-PA)/Wv where
    W= Water evaporization rate, (lbs/hr) per sq. ft. of water surface area
    A= Constant 68, B= Constant 32
    V= Velocity over water surface, miles/hr
    Pw= Vapor pressure of water at the water temperature, inches of Hg.
    Pa= Vapor pressure of water at the air dewpoint temperature, inches of Hg
    Hv= Heat of vaporization of water at the water temperature, Btu/lb
    I came across this formula on a spread sheet that was used for another project but I can not find anything to confirm if it is correct. Also, I'm not sure what the constants are based on.
    Any help would be greatly appreciated,
    JJW
