Water in an open container immersed in a heat bath at BP
An open test tube containing water does not boil when immersed in a boiling water bath due to the balance of heat flow and heat loss. The water in the test tube can reach a temperature where both liquid and vapor phases coexist, acting as a crude thermometer. Heat conduction is the primary mechanism at play, with convection and radiation becoming more significant at different temperatures. Heat flows from the hotter boiling water to the cooler test tube, but if heat loss from vaporization and the test tube body exceeds heat gain, the water will not boil. Achieving thermal equilibrium may eventually lead to boiling if the heat flow conditions change.
LuxAurum
I realize this is probably pretty basic, but it has me stumped:
An open test tube containing water is immersed in a heat bath of boiling water. The water in the test tube does not boil. Why?
Would this be because the water in the test tube is at a temperature where it two phases (liquid and vapor) co-exist?
Science news on Phys.org
What you have is a crude type of thermometer, and evidently this shows how when measuring temperature by any instrument you have to be sure it is indicating the temperature accurately.
Primarily this a heat conduction problem ( and phase change for this particular case )at this temperature, although convection and radiation will play a part, more so at different temperatures, radiation most especially at higher temperatures.
Heat flows from a hotter body to a colder body.
For heat to flow into the test tube, it has to be at a lower temperature, however slight that may be, than the heat bath. The greater difference in temperature the more heat will flow, diminishing as the temperature difference decreases. This is one type of thermal lag effect.
As the temperature of the water in the test tube increases, and turns into vapour, heat is taken away. There is also a heat loss from the test tube body exposed to the air.
We thus have heat flow from the boiling water bath into the test tube through a barrier and heat being removed via the vapour and the test tube body. If the heat being removed is greater than that entering then the test tube water will not boil.
If you immerse the whole apparatus in a room such tht suppose the steam collected from the bath remains at the same temperature of the bath, several of these sources of 'error' can be minimized or eliminated, you will then have the conduction from the bath through the test tube wall to test tube water being the 'source of error' for your crude thermometer. If then you wait long enough, the test tube water should begin to show signs of slight boiling if and when the two masses come to thermal equilibrium.
Likes 1 person
Thank you very much! This answers my question perfectly!
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
