Can Wave Function Constants Be Both Positive and Negative?
terp.asessed
I am curious if the constants for wave functions for a particle in a box can be both +/-...because constants I've applied for wave functions have always been +...
Wave functions that differ only by an overall phase factor ##e^{i \phi}## represent the same physical state, as no observable changes due to this complex phase. Hence, multiplying the constant by ##-1## will not change the physics. Taking the constant to be real and positive is often simply a matter of convention.
Likes bhobba and terp.asessed
Thank you for the explanation!
Hi guys,
Just started studying physics hence I obviously have a silly question for you.
Why the wave function Ψ (x,y,z) must be square. It seems wave functions themselves have no meaning if they don't have a physical meaning.
Thanks a lot in advance,
Rodos
Thanks Bill. I will check it out.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
Not an expert in QM. AFAIK, Schrödinger's equation is quite different from the classical wave equation. The former is an equation for the dynamics of the state of a (quantum?) system, the latter is an equation for the dynamics of a (classical) degree of freedom. As a matter of fact, Schrödinger's equation is first order in time derivatives, while the classical wave equation is second order. But, AFAIK, Schrödinger's equation is a wave equation; only its interpretation makes it non-classical...
According to recent podcast between Jacob Barandes and Sean Carroll, Barandes claims that putting a sensitive qubit near one of the slits of a double slit interference experiment is sufficient to break the interference pattern. Here are his words from the official transcript: Is that true? Caveats I see: The qubit is a quantum object, so if the particle was in a superposition of up and down, the qubit can be in a superposition too. Measuring the qubit in an orthogonal direction might...
