Wave-particle duality question
autonomous
i was wondering, what if you shined two parallel rays of light directly next to each other and shot the particle throught them, one being a short wavelength and the other a long wavelength and measured each one. the first ray of light would find the momentum, so when u found the position you could already know its momentum. would this be accurate, considering the speed of the particle is constant?
if you untirely understand what I am saying, its basically to help find a particles position and momentum, sense the whole wave-particle duality is about how its impossible to find both because once you find one you now no less of the other. a shorter wave length will help you find the position, and the longer wave length helps you find the momentum, or maybe its the other way around, but this is what I've read, and no one has ever tried doing both so i figured it may be possible. just read up on the 'wave-particle duality' and you will know more of what my earlier post is asking.
Search and read up on the EPR paradox, you might be enlightened to know that you weren't the first one to propose the collapse of the uncertainty principle.
autonomous said:
i was wondering, what if you shined two parallel rays of light directly next to each other and shot the particle through them, one being a short wavelength and the other a long wavelength and measured each one. the first ray of light would find the momentum, so when u found the position you could already know its momentum. would this be accurate, considering the speed of the particle is constant?
For your plan to work, you're going to have to measure momentum first, then position. Clearly if you reversed the order, you'd end up screwing up the momentum and get the Heisenberg limit.
So your question really comes down to this. When you make a measurement of momentum, does it also screw up later measurements of position?
The answer is that it does. In QM, to make an accurate measurement of momentum requires that the particle be placed in an approximate eigenstate of the momentum operator. The math then shows that its position cannot be accurately determined.
By the way, the EPR experiment involves correlated particles being measured, one for momentum, the other for position. In your case, you only have one particle, so the Heisenberg uncertainty principle does, in fact, apply.
Carl
The discussion here is quite complete.
https://www.physicsforums.com/showthread.php?t=78949
To be even clearer, it won't have a localised position in the classical sense
which is subject to discovery. But it will acquire one if and when a position
measurement is made.
I use the funny verbiage "subject to discovery" because in english the
word "determine" has two meanings and is the source of much confusion
on this topic.
It is interesting to note that if you perform one masurement you may find experimental results for position and momentum with as high precision as you want.
The HUP enters the discussion when you try to associate these values of position and momentum to a certain time, a certain initial state and a certain set of physical influences (Hamiltonian). By doing a set of identical experiments you will find statistical dispersion on these results, and it is exactly at this point that HUP appears, if I understood it well.
Best Regards
DaTario
I am not sure if this belongs in the biology section, but it appears more of a quantum physics question. Mike Wiest, Associate Professor of Neuroscience at Wellesley College in the US. In 2024 he published the results of an experiment on anaesthesia which purported to point to a role of quantum processes in consciousness; here is a popular exposition: https://neurosciencenews.com/quantum-process-consciousness-27624/ As my expertise in neuroscience doesn't reach up to an ant's ear...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. Towards the end of the first lecture for the Qiskit Global Summer School 2025, Foundations of Quantum Mechanics, Olivia Lanes (Global Lead, Content and Education IBM) stated... Source: https://www.physicsforums.com/insights/quantum-entanglement-is-a-kinematic-fact-not-a-dynamical-effect/ by @RUTA
I am reading WHAT IS A QUANTUM FIELD THEORY?" A First Introduction for Mathematicians. The author states (2.4 Finite versus Continuous Models) that the use of continuity causes the infinities in QFT: 'Mathematicians are trained to think of physical space as R3. But our continuous model of physical space as R3 is of course an idealization, both at the scale of the very large and at the scale of the very small. This idealization has proved to be very powerful, but in the case of Quantum...
